Steering rod ends
Old Jun 27, 2002 | 11:10 AM
Kolijian's Avatar
Default Steering rod ends
how big of a job is ti to replace these?
I was getting my alignment done and the mech. noticed that I needed new ones. Not even sure how you can tell when they are worn....but I've got to get em.
So anyone else had to do this??
Old Jun 27, 2002 | 05:42 PM
IN VTEC's Avatar
Default Re: Steering rod ends (Kolijian)
The steering tie rods are used to adjust the toe on the front suspension. He probably noticed that he couldn't get the toe within spec or it was fluctuating too much.
I'm in the process of replacing the tie rods too. Honda OEM tie rods are about $30 to $35 a piece. The local Honda dealer ($65 labor rate) quote me $55 to replace it, but it was with an aftermarket piece from Napa or Carquest.
If you wanna DIY, you'll need a 19mm and I believe a 20mm or 21mm open-end wrenchs, a Pitman Arm Puller, pliers to pull out the cotter pin, 17mm socket, and possibly a breaker bar to fit over the 20/21mm wrench.
You can rent the Pitman Arm Pulley from Autozone for $20, fully refundable.
The hardest part is getting the 20/21mm tie rod locknut broken loose. After that, it's a piece of cake.
Old Jun 28, 2002 | 02:58 AM
kinesistech's Avatar
Default Re: Steering rod ends (IN VTEC)
When you removed it be sure to remember how many turns it is adjusted, otherwise you WILL need a wheel alignment after the install.
Old Jun 28, 2002 | 05:17 AM
IN VTEC's Avatar
Default Re: Steering rod ends (kinesistech)
He'll want an alignment afterwards regardless just to be sure it's within spec.
Old Jun 28, 2002 | 07:18 AM
Kolijian's Avatar
What are all the parts or parts #'s that I'll need. I just got a call my from my mech, and there seems to be a part missing or something, I wasn't sure what he was saying, I'm so pissed!!!!
i think I need a new car, some new **** every other day
JJ291
Honda Civic (2001 - 2005)
Jul 26, 2013 05:28 AM
msinsky14
15
May 3, 2007 11:21 AM
TAG
Apr 22, 2005 08:05 PM
vultron
Nov 11, 2004 07:05 AM
patastinky
Jul 29, 2004 12:07 AM
