Pulsing dash lights?????
Old Dec 15, 2007 | 10:07 AM
si_motor_spt's Avatar
Default Pulsing dash lights?????
Hey guys, well i was wondering, before when i started and drove my car my volt meter would read 14.5 volts with all my accessorys(gauges,etc) but now when i start it in the morning, it fluctuates between 14.5 to 12.8 and the dash lights flicker and so do my headlights when their on but when i drive it just stays on 12.8 volts????? would any one know the explanation for that???? any info is appreciated
Old Dec 15, 2007 | 11:05 AM
fdavie's Avatar
Default Re: Pulsing dash lights????? (si_motor_spt)
Alternator problem of some sort.... 14.5 is a little high
Old Dec 15, 2007 | 02:29 PM
Default Re: Pulsing dash lights????? (fdavie)
Its got a brand new alternator and before i got my new alternator it was still fine but i just cant seem to figure it out... any other thoughts peeps...????
Old Dec 15, 2007 | 04:03 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_motor_spt &raquo;</TD></TR><TR><TD CLASS="quote">Its got a brand new alternator and before i got my new alternator it was still fine but i just cant seem to figure it out... any other thoughts peeps...????</TD></TR></TABLE>
how are your grounds? but is sounds like you dimmer switch is about to check out.
Old Dec 15, 2007 | 05:13 PM
fdavie's Avatar
Default Re: Pulsing dash lights????? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
how are your grounds? but is sounds like you dimmer switch is about to check out.</TD></TR></TABLE>
I'd go with grounds too, since your alternator's new. I doubt its the dimmer, since the headlights flicker too.
Old Dec 15, 2007 | 05:17 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdavie &raquo;</TD></TR><TR><TD CLASS="quote">
I'd go with grounds too, since your alternator's new. I doubt its the dimmer, since the headlights flicker too.</TD></TR></TABLE>
?HUH? WHAT?
when the dimmer switch goes out, the headlights do not flicker. you do know i'm talking about the grey dimmer switch on the dash, not the headlight switch around the steering column.
Old Dec 15, 2007 | 06:28 PM
slo_hatch's Avatar
probably grounds...but could be your dimmer swicth. mine would just come on and then i would hit a bump and they would go out...and a friend's would almost never work till she hit the dash where the dimmer switch is and they would come on.
Old Dec 15, 2007 | 07:26 PM
laocivic's Avatar
Default Re: Pulsing dash lights????? (slo_hatch)
u got a system? or anything like that? when i had a 900 watt system hooked up and my battery was near end of its life the lights started flickering with the beat of that bass...prolly not your prob but it might help someon else
Old Dec 15, 2007 | 11:57 PM
fdavie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">when the dimmer switch goes out, the headlights do not flicker. </TD></TR></TABLE>
Read the OP. He said his headlights flicker when they're on. Since the dimmer would not make the headlights flicker, it's not the dimmer.
OP: Grounds! take 'em all of, hit 'em with some emery cloth, and tighten 'em back. If that doesn't do it, check your battery terminals. It's something in that charging system.
Old Dec 16, 2007 | 02:10 AM
sharik's Avatar
Buy a cheap groundign system on ebay, i know its fugly but it helps with the ground......
ac_attak
Dec 18, 2006 04:27 PM
MarksIntegra
Nov 24, 2006 12:27 AM
HondaBurger
Oct 30, 2006 08:13 AM
92silude
Jun 14, 2005 12:11 PM
conesmasher
Mar 4, 2004 08:14 PM
