95 accord coolent bleeding issue
Old Dec 15, 2007 | 01:05 AM
verticaledge's Avatar
Default 95 accord coolent bleeding issue
ok so why would my system not bleed anything ever? Im doing the whole procedure just like it says in my service manual and nothing ever happens...what would cause this??? thanks!
Old Dec 15, 2007 | 09:20 AM
accord_2dr's Avatar
Default Re: 95 accord coolent bleeding issue (verticaledge)
explain how you are doing it
Old Dec 15, 2007 | 09:27 PM
H22_aCCoRd_07's Avatar
Default Re: 95 accord coolent bleeding issue (accord_2dr)
yeah... descibe what its doing
Old Dec 15, 2007 | 11:11 PM
Default Re: 95 accord coolent bleeding issue (H22_aCCoRd_07)
okkkk im starting the car, filling the thing up full of coolant and cracking that bleed screw.....nothing ever comes out and I can actually take that bleed screw out and it will be bone dry....I dont understand it.... a few people have told me that my thermostat might be stuck closed....could that be the problem? I dont know if that can even be it because the car temp goes exactly to where its supposed to and never tries to overheat.
Old Dec 16, 2007 | 05:06 AM
hondaccord's Avatar
have you checked the cap to make sure it is holding proper pressure?
Old Dec 16, 2007 | 07:48 PM
mark2583's Avatar
Default Re: 95 accord coolent bleeding issue (hondaccord)
mine is doing the same thing and my mechanic says that my head gasket is going bad.
Old Dec 16, 2007 | 08:15 PM
Default Re: 95 accord coolent bleeding issue (mark2583)
thats what i was thinking also but i just put this motor in and its got very low miles....
Old Dec 16, 2007 | 10:54 PM
hondaccord's Avatar
well do you see any coolant in the oil?
Old Dec 16, 2007 | 11:00 PM
Chrisfball12's Avatar
the best thing you can do is remove your thermostat and put it in boiling water and with a thermometer check when it opens. Then check what temp your thermostat should work at
Old Dec 16, 2007 | 11:42 PM
Default Re: 95 accord coolent bleeding issue (Chrisfball12)
yeah i pulled the t-stat out earlier and bought a new one...I mien 15 bucks...i dont really care if the other one was still working or not lol. but yeah the old one looked really nasty and torn up so its probably on its way out anyway.....and i dont know about any coolant in the oil...this is the first oil I have put into the motor cause its new and when i got it, it was empty....that damn head gasket better not be messed up....
Old Dec 18, 2007 | 04:03 PM
wadman's Avatar
try filling ur rad with bleeder open and the engine off fill until u see a steady stream of coolant at bleeder.
Old Dec 19, 2007 | 10:26 AM
Honda-Master's Avatar
engine off, loosen the 12 mm nipple at the t-stat housing, fill the radiator, when rad is full and coolant still does not comes out,,, remove the nipple totally, get a paper clip or a thin pin, stick it in the hole where you removed the nipple from,, I have seen it numerous times where the hole gets plugged.. Also is the car on a level ground ??
I have never seen a head gasket, or a bad t-stat or a bad radiator cap cause this issue
youdntcme
Jul 28, 2013 07:12 AM
robmarsh781
Nov 26, 2012 11:19 PM
bunnyx
Mar 18, 2009 08:52 AM
IBriaIN
Apr 6, 2006 02:27 PM
