Help with d series
I have a d15 bottom end and the head gasket is leaking and the head is a little worn(noisey 230k)... i have a d16 head, non vtec, with only 40k on it i was just wondering would they bolt up? i am famillar with b series and know the heads on those blocks are interchangable with little work.. if it is interchangable what is needed to be done?
thanks
John
thanks
John
They are right.
A6 cam is a bit more aggressive too than the B7. Get an adjustable cam gear or get the OEM one from a D16Y7.
FYI- I swapped cams in my B7 and noticed a significant difference up top till red line.
Blahblah718293
Apr 8, 2010 06:45 PM
