When converting OBD0 to OBD1 what engine harn. do you use?
i'm putting z6 in my 91 crx si. do i use the si harn. or do i use the new one. will the new one plug in to my engine bay harn.
You modify the existing harness on the engine bay side, and you use a converter harness that plugs into your stock harness on the ECU side.
so what do i need to get i thought the obd0-1 harn. you bought was for the ecu part?
Jason
yeah w/ an obd1 motor all you have to do is extent wires off your existing obd0 engine harness. its cake
yeah, you just gotta do stuff like change the distributor plugs, add the 4 wire 02 sensor, extend the MAP sensor wires, change injectors, remove the injector resister, stuff like that.
so when i get the harn. i still need to get another for the p28 ecu to plug in.
what do you mean when you say "extend" the wires?
Blown90Hatch... you don't have to take out the injector resister???? I thought you had to because of the different voltage of the newer injectors! Not to mention that my stock injector clips would not fit on the new injectors.
[Modified by 89_Y_49, 6:11 PM 6/28/2002]
Exactly what I said... Splice in a length of wire to make the plugs reach.
hatchinprogress
10
Jul 13, 2005 04:05 PM
0ptimus prime
Aug 20, 2004 09:14 AM
