Radiator is not working
Old Dec 14, 2007 | 06:57 PM
creepy116's Avatar
Default Radiator is not working
i noticed my radiator fan isn't working i checked all the fuses and nothing is burnt
Old Dec 14, 2007 | 07:09 PM
da_dude's Avatar
Try hot wiring the radiator fan directly to the battery and see if the fan comes on or not.
Old Dec 14, 2007 | 07:13 PM
creepy116's Avatar
Default Re: (da_dude)
how do i do that?
Old Dec 14, 2007 | 08:04 PM
slowcivic e g's Avatar
Default Re: (creepy116)
unclip the fan, and either cut the clip off, or touch 1 wire to each pin in the clip coming off the fan motor and touch one wire to the pos. batt and 1 to the neg. batt.post. if it comes on there is a problem in your wiring, fusebox or fan switch. you can just wire it straight to your ignition or your battery with a switch.
Old Dec 14, 2007 | 08:12 PM
pearlcfcivic97's Avatar
did you plug it in after your swap?
Old Dec 14, 2007 | 08:31 PM
creepy116's Avatar
Default Re: (pearlcfcivic97)
yes i plugged it in after my swap
Old Dec 14, 2007 | 08:37 PM
SLO Sol's Avatar
the fan will not come on right away
Old Dec 14, 2007 | 08:44 PM
creepy116's Avatar
the car ran for like 5 mins, still no fan
Old Dec 14, 2007 | 08:56 PM
it doesnt come on until it needs too, as in when the coolant is going throught the radiator and still not getting cool cause your not moving
Old Dec 14, 2007 | 09:38 PM
creepy116's Avatar
mayb thats why, because i just tried to hot wire the fan and its working fine. ill get back to you guys on this one tomorrow, when i run my car
Old Dec 14, 2007 | 09:44 PM
its probably just fine, just watch your temp guage and make sure you get all the air out of the system...
Old Dec 14, 2007 | 10:03 PM
creepy116's Avatar
ok thanks for help
Old Dec 14, 2007 | 10:09 PM
obuhmyuh's Avatar
yeah i wired a switch to my driver's side on my console, and i just turn it on when my engine's warm, kinda pointless unless im driving long-distance or its hot out, but it looks cool 5 bucks from radio shack has a red led light and a red cover
Old Dec 14, 2007 | 10:10 PM
its extremly pointless considering thats what it does normally... and when you forget and your engine overheats
Old Dec 14, 2007 | 10:11 PM
Default Re: (d[sick]sTeena)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d[sick &raquo;</TD></TR><TR><TD CLASS="quote">sTeena]yeah i wired a switch to my driver's side on my console, and i just turn it on when my engine's warm, kinda pointless unless im driving long-distance or its hot out, but it looks cool 5 bucks from radio shack has a red led light and a red cover</TD></TR></TABLE>
do you have it right next to your 5 inch tach on your dash?
Old Dec 14, 2007 | 10:38 PM
fmrprojects's Avatar
it only works when it has too. if you really wanna hear it turn on, let your car sit and idle for 30 minutes and the fan will turn on
Old Dec 14, 2007 | 10:42 PM
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">it only works when it has too. if you really wanna hear it turn on, let your car sit and idle for 30 minutes and the fan will turn on</TD></TR></TABLE>
Thank you......
Old Dec 15, 2007 | 09:57 AM
obuhmyuh's Avatar
mine wouldn't turn on no matter how long i let it run or how far i drove and it was the only practical idea at the time, and now its not next to my tach its next to my leg.
Old Dec 15, 2007 | 11:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d[sick &raquo;</TD></TR><TR><TD CLASS="quote">sTeena]mine wouldn't turn on no matter how long i let it run or how far i drove and it was the only practical idea at the time, and now its not next to my tach its next to my leg.</TD></TR></TABLE>
lol going stealthy
Corksil
Dec 9, 2009 06:56 PM
ShinotakuX
Dec 14, 2007 08:20 PM
jetmex
Jul 2, 2005 08:31 AM
jDMJeRk
May 4, 2005 07:43 PM
