Lighting HID/Xenon kits, Retrofits and Associated Topics
USED HID KIT INSTALL?? HELP...
Old Dec 14, 2007 | 05:20 PM
Samuels's Avatar
Default USED HID KIT INSTALL?? HELP...
Ok i bought a used 9006 Xenon kit obviously it comes with no instructions but everything is plug and play. It has a ground but do you hook the power wire up to the battery??
Not sure because its constant power can anyone help me out??
Old Dec 14, 2007 | 06:04 PM
prelude1897's Avatar
Default Re: USED HID KIT INSTALL?? HELP... (Samuels)
This might help you out
Old Dec 14, 2007 | 06:41 PM
imroadk1ll's Avatar
havent seen a hid kit that does a ground with it. where did you buy your kit from?
Old Dec 14, 2007 | 06:55 PM
Samuels's Avatar
Default Re: (imroadk1ll)
a local guy.. he said to just ground the black wire to the chassis and run the red to the battery. I'm just checking i was'nt sure if you should run it constant power..
Old Dec 14, 2007 | 07:01 PM
hometheaterman's Avatar
You should be able to connect a constant power up to the battery but make sure you put an inline fuse in.
greddy2smoke
Honda Civic (2006 - 2015)
Jun 19, 2009 07:00 AM
Importn2oRacer
Lighting
May 17, 2008 01:06 PM
datssoled
Mar 29, 2007 03:22 PM
g5h22
Apr 24, 2004 08:03 PM
