I need help!!!!!
Old Dec 14, 2007 | 01:29 PM
SiRkid1's Avatar
Default I need help!!!!!
I believe I have a 89 jdm b16 block off a jdm crx and a 98 gsr head. I'm trying to change the head gasket but dont know what gasket to purchase. Can anybody please help me out I would really appreciate it. The reason why I want to change the head gasket is because my car is leaking a lot of oil and see oil between the head and block. I already changed the vc gasket. Feel free to share any input. Thank you in advance.
Old Dec 14, 2007 | 03:53 PM
SiRkid1's Avatar
Default Re: I need help!!!!! (SiRkid1)
Please help me out.
Old Dec 17, 2007 | 01:56 PM
SiRkid1's Avatar
wow really nobody can help me???
Old Dec 17, 2007 | 02:20 PM
h22crxpwr's Avatar
sure its not coming from the cam seal? that can pool around the head as well...
check that before you take the head off...
Old Dec 18, 2007 | 09:55 AM
slomofo's Avatar
GDD Member
B16A and B18C can use the same head gasket, so it doesn't matter which one you get.
Both blocks have 81mm bores, both blocks are open deck, both blocks and heads have all the same holes for water jackets and oil.
Old Dec 20, 2007 | 09:52 AM
SiRkid1's Avatar
Default Re: I need help!!!!! (h22crxpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr &raquo;</TD></TR><TR><TD CLASS="quote">sure its not coming from the cam seal? that can pool around the head as well...
check that before you take the head off... </TD></TR></TABLE>
pmd
SiRkid1's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">B16A and B18C can use the same head gasket, so it doesn't matter which one you get.
Both blocks have 81mm bores, both blocks are open deck, both blocks and heads have all the same holes for water jackets and oil. </TD></TR></TABLE>
thank you very much.
Old Dec 20, 2007 | 11:01 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid1 &raquo;</TD></TR><TR><TD CLASS="quote">
pmd</TD></TR></TABLE>
pmd back,
mijos
Sep 5, 2020 05:56 PM
pooRmansss
Feb 19, 2009 03:24 PM
slowassciv33
16
Sep 17, 2006 04:33 PM
JDMAN
Apr 7, 2004 05:25 PM
UNDER PRESSURE
Oct 6, 2003 08:37 AM
