oil squriter removel
Old Dec 14, 2007 | 12:59 PM
jordan2305's Avatar
Default oil squriter removel
can i take my oil spuriters out of my block and plug the hole. to put a ls crank in it will it hurt anything.
Old Dec 14, 2007 | 01:02 PM
Luserkid's Avatar
Default Re: oil squriter removel (jordan2305)
What pistons are you going to be using? You could cap them and it will raise oil pressure by i think 5psi. What block is this anyway?
Old Dec 14, 2007 | 01:06 PM
jordan2305's Avatar
Default Re: oil squriter removel (Luserkid)
95 gsr block with eagle h beam rods and aftermarket piston low comp for boost.
Old Dec 14, 2007 | 01:50 PM
Luserkid's Avatar
If its for boost why are you trying to stroke it? If they are aftermarket pistons then youll be fine not running squirters.
Old Dec 15, 2007 | 04:27 AM
jordan2305's Avatar
thank you
Old Dec 15, 2007 | 04:28 AM
pdiggitydogg's Avatar
youre going to use ls rods on that i hope
rsxmachine
Jan 19, 2012 03:49 PM
joedeezy
Oct 21, 2008 08:48 PM
spooledex
Dec 22, 2006 11:13 PM
kevs-ej1
Nov 28, 2005 06:20 AM
fastludeh22
Jul 19, 2002 03:56 PM
