What can i do to make my car quieter?
Old Dec 14, 2007 | 10:53 AM
angel_i's Avatar
Default What can i do to make my car quieter?
I have a 2000 EX w/ LS swap, gutted cat, stock intake, and I THINK stock exhuast. I do a lot of drivin and I hate road noise. I want my car to sound like a Lexus when i'm done and i need some suggestions to help quiet the interior noise. I was thinking Dynomat, but its expensive so I want to take another route. Would rubberized undercoating, on the inner fenders, undercarriage, and trunk area help alot? I was thinking of sprayin some on the inner door panels, under the carpet, and well basically everywhere that paint shows. Do yalll got any suggestions?
Old Dec 14, 2007 | 10:57 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: What can i do to make my car quieter? (angel_i)
A Civic will never sound like a Lexus, first off. Secondly, get a new cat. 2hp isn't worth raspiness. That said, you may get more benefit by asking this in the Pant/Body forum.
Old Dec 14, 2007 | 11:21 AM
angel_i's Avatar
It isn't raspy, and yeah it'll be hard making it quiet
Old Dec 14, 2007 | 11:22 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angel_i &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000 EX w/ LS swap, gutted cat, stock intake, and I THINK stock exhuast. I do a lot of drivin and I hate road noise. I want my car to sound like a Lexus when i'm done and i need some suggestions to help quiet the interior noise. I was thinking Dynomat, but its expensive so I want to take another route. Would rubberized undercoating, on the inner fenders, undercarriage, and trunk area help alot? I was thinking of sprayin some on the inner door panels, under the carpet, and well basically everywhere that paint shows. Do yalll got any suggestions?</TD></TR></TABLE>
did you get that idea from the HT member who sprayed that bed liner crap all over the interior of his car?
not sure how much that will benefit, but will add more weight to your car.
and if you want your car to be more quiet, then add the stock intake in and get a new cat, that right there is probably about 30% of your noise.
Old Dec 14, 2007 | 11:48 AM
angel_i's Avatar
Got the idea from riding in my buddy's CTS. Weight isn't an issue.
Old Dec 14, 2007 | 11:53 AM
Eran's Avatar
HT White Ops
Cascade makes some really good dampening material in both sheet and spray form. Generally cheaper than 'Dynamat' as well.
http://www.cascadeaudio.com/ca...x.htm
Old Dec 14, 2007 | 11:54 AM
philosofy1's Avatar
Default Re: (angel_i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angel_i &raquo;</TD></TR><TR><TD CLASS="quote">Got the idea from riding in my buddy's CTS. Weight isn't an issue.</TD></TR></TABLE>
you can't compare a CTS or a Lexus to a civic. tons of research and development is what has led those cars to be so quiet and smooth. the amount of money you would spend trying to quiet your honda, you might has well buy a Lexus or CTS.
you really want to help make you honda quiet. get a new oem replacement cat. hit up the muffler shop and see if they can add another resonator to your exahaust.
what type tires do you have? tires to play a roll in road noise.
truevietluv636's Avatar
Default Re:
i've tried the undercoating on my old car and it didnt help much, you would probably have to spray a few layers to notice something.
Old Dec 14, 2007 | 01:59 PM
NonovUrbizniz's Avatar
Loved
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
what type tires do you have? tires to play a roll in road noise. </TD></TR></TABLE>
I'm sorry but that's just ignorant....
If you do what the above poster said in relation to the additional resonator and stock cat that will obviously quite you down quite a bit... same for the stock intake...
HOWEVER if you spray all 4 wheel wells with ruberized under coating that will eliminate a HUGE amount of road noise... for even more effective sound deadening of road noise you can remove the wheel well liners and spray the metal structure underneith it as well as the backside of the wheel well plastic... then re-install and spray the side that faces out once re-installed.
If you run dynomat or equivalant that will again reduce noise pretty dramatacally...
Then if you wanna go nuts you can use some of the other products from the sound deadening companies it will only increase the quite...
I did b-quite extreme on the entire trunk and floorboards of the passenger cabin and it made a HUGE difference even with the carpet still out.
Then they sell products like vcomp and lcomp which are layerd with foam as well as the tar/aluminum which will offer even more sound deading.
You can make the car VERY quite... the only thing that highdollar companies like lexus/bmw etc. can do that we can't is the double pained glass which does make a HUGE difference once everything else is all sealed up.
for 400-1000 in sound deading (and god knows how many hours) I'd bet dollar to dime you could be QUITER than a lexus in a civic.
Old Dec 14, 2007 | 02:11 PM
angel_i's Avatar
just the inspiration that i needed!
Old Dec 14, 2007 | 02:26 PM
Budget Racer's Avatar
Hmm ignorant.
Spellcheck: Quite should be Quiet. LOL
P.S. Don't get mad I'm jus playin.
Old Dec 14, 2007 | 03:49 PM
Eddieman201's Avatar
Default Re: (Budget Racer)
yeah this matting call raamat and is alot cheaper than dynamat.
go to diycaraudio and look around on the forums for more info
davey5300
Jan 24, 2008 04:26 PM
00garrettsi
Sep 10, 2007 04:48 PM
subhu1030
Apr 27, 2007 06:11 AM
spoonef
17
Dec 5, 2005 11:38 AM
euclid
11
May 7, 2003 10:08 PM
