Frame rail damage drivers side. And home remedy tool i can use to bend it up to straighen it?
Old Dec 14, 2007 | 01:27 AM
Frost7177's Avatar
Default Frame rail damage drivers side. And home remedy tool i can use to bend it up to straighen it?
It is bent down like and inch and i bought a new rad support and a new front end does anyone know what i can use? A 3 ton jack and some wood and jack it up on the rail? I shouldnt def heat it up?
Old Dec 14, 2007 | 02:46 AM
DaveF's Avatar
Default Re: Frame rail damage drivers side. And home remedy tool i can use to bend it up to straighen it? (F
you car going to need something to hold it in place, and i doubt you are going to get it back to "right" using this method. most likely.... go to a body shop, and have them put it on the frame rack to pull it back straight.
Old Dec 17, 2007 | 01:39 AM
civic.slow's Avatar
* B A N N E D *
expletive it, put a chain on your frame and take off in a 3500HD
Old Dec 17, 2007 | 07:33 AM
m R g S r's Avatar
body shops charge by the hour...if the car is drivable, then bring it down to the body shop and have them roll it onto the frame straightening machine and straighten it.. shouldn't be more than two hours of work if its not bad like you claim...thats only $120 or so from an average shop. btw...even if the car doesnt run/drive, towing to and from the shop shouldn't be much, maybe another $100 or so. it's worth it to be able to have everything line up rather than half assing it and having a crooked lookin car with large uneven gaps in the body panels.
Old Dec 19, 2007 | 08:34 AM
hurtgen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic.slow &raquo;</TD></TR><TR><TD CLASS="quote">expletive it, put a chain on your frame and take off in a 3500HD </TD></TR></TABLE>
my buddy's dad did that to his camaro with his dodge ram. drives straight now.
Old Dec 20, 2007 | 11:18 AM
HiProfile's Avatar
The best part about the chassis shop, assuming its a good one, they will have ALL the measurements for your chassis. My bro will be using one of his shop's manuals to help me see if my car is fine before I put the rad support on.
Worst thing you can do is weld it on, and find out something else is bent to hell. I'd rather spend 2-3 hours on a chassis rack than <U>re-</U>drilling all the spot welds out.
btw heating the metal w/o any control could anneal it, making it softer, or harden it, making it brittle. And I doubt that the car weighs enough for a jack to help much.
Old Dec 21, 2007 | 12:31 PM
mkw1's Avatar
drive the car on a car trailer, chain the car down around the crossmember and around the other rail to hold the car down then jack it up with a 3 ton floor jack. presto instant frame rack
Modified by mkw1 at 4:08 PM 12/21/2007
kisska25
Paint and Body
Oct 19, 2008 06:58 PM
imonx850
Mar 11, 2005 10:15 PM
RooskiGSR
Jan 10, 2005 09:50 AM
AllmansDB8*
Apr 5, 2004 03:38 PM
Audipwr1
May 8, 2003 08:27 PM
