transmission problems on 1990 accord HELP!!!
Old Dec 13, 2007 | 02:12 PM
butterflychica's Avatar
Default transmission problems on 1990 accord HELP!!!
My auto trans on my 90 accord coupe, has been acting up it will not shift through the gears. I have been manually shifting it and its getting old aswell as it not having any reverse, it just makes a grinding noise when in reverse but wont move. The car sat in a field for two years, and it has a few random electrical problems, so I am thinking its electrical..ANY INFO HELPS THANKS
Old Dec 13, 2007 | 04:16 PM
hondadude's Avatar
Default Re: transmission problems on 1990 accord HELP!!! (butterflychica)
have you jumpered the service connection and checked for any codes?
Old Dec 14, 2007 | 12:50 PM
Default Re: transmission problems on 1990 accord HELP!!! (hondadude)
no i dont have a computer scanner
Old Dec 14, 2007 | 01:52 PM
cb7tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by butterflychica &raquo;</TD></TR><TR><TD CLASS="quote">My auto trans on my 90 accord coupe, has been acting up it will not shift through the gears. I have been manually shifting it and its getting old aswell as it not having any reverse, it just makes a grinding noise when in reverse but wont move. The car sat in a field for two years, and it has a few random electrical problems, so I am thinking its electrical..ANY INFO HELPS THANKS</TD></TR></TABLE>
swap out the tranny. the car is 17 years old. i'm sure the tranny has seen better days
Old Dec 14, 2007 | 02:22 PM
Default Re: transmission problems on 1990 accord HELP!!! (cb7tuned)
i have no gargae and olny 6 fingers not gonna happen
Old Dec 14, 2007 | 02:37 PM
honda_kid42's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by butterflychica &raquo;</TD></TR><TR><TD CLASS="quote"> olny 6 fingers </TD></TR></TABLE>
HUH???
is your CEL light on???
Old Dec 14, 2007 | 03:16 PM
Default Re: transmission problems on 1990 accord HELP!!! (honda_kid42)
the sport mod lite is always on i think its suppose to be flashing only when in sport . i just bought a new tranny computer
Old Dec 14, 2007 | 05:02 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by butterflychica &raquo;</TD></TR><TR><TD CLASS="quote">no i dont have a computer scanner</TD></TR></TABLE>
You don't need a scan tool.
Jumper the BLUE 2 pin connector that is located above the passenger side kick panel, turn on the key and count the 'S' lite flashes
Old Dec 15, 2007 | 10:47 AM
hilltopgraphics's Avatar
If the car is making a grinding noise in reverse, it usually means the reverse selector gear and shift fork are damaged. This is a typical Honda issue. Chances are, the ferrous contamination from the damaged splines has made its way into your strainer, and possibly a shift valve.
The transmission needs to be replaced.
Old Dec 17, 2007 | 07:17 PM
Default Re: transmission problems on 1990 accord HELP!!! (hilltopgraphics)
finally a straight answer thanks boss ...... son of a beach she needs a tranny.
Old Dec 18, 2007 | 12:54 PM
No problem. Just throwin' my 2 cents at a $1000 issue.
Randy Reed
Jun 3, 2016 06:09 PM
bmk2001
May 25, 2011 10:58 AM
JDM H23A
Dec 8, 2006 04:10 PM
JDMCRX
Mar 21, 2004 05:15 PM
