GSR Enginge Internal Aftermarket Products
Old Jun 27, 2002 | 07:59 AM
GSR95TEG's Avatar
Default GSR Enginge Internal Aftermarket Products
What are the best aftermarket products for an engine rebuild??? Im looking at spending a few G's on parts.
Old Jun 27, 2002 | 08:14 AM
green_GSR's Avatar
Default Re: GSR Enginge Internal Aftermarket Products (GSR95TEG)
Pistons -- TODA, JUN, JE, SRP, Arias, Honda OEM (ITR, JDM ITR, CTR)
Rings -- Honda OEM
Rods -- Eagle, Crower, Honda OEM (ITR)
Rod Bolts -- ARP
Head Studs -- ARP
Head Gasket -- Honda OEM, TODA, Cometic
Bearings -- Honda OEM
Oil Pump Gear -- TODA
Just make sure you find a good shop to do the rebuild.
[Modified by green_GSR, 9:15 AM 6/27/2002]
Old Jun 27, 2002 | 08:39 AM
BSQ's Avatar
BSQ
Default Re: GSR Enginge Internal Aftermarket Products (green_GSR)
Rings -- Honda OEM
Rod Bolts -- ARP
Head Studs -- ARP
These are all good recommendation by green_GSR. But my first question would be what is your plan for the engine (NA, turbo, supercharger)? If you go all motor how much compression are wanting to run (if mild compression), then there really is no need to upgrade the stock rods. If you are not wanting to increase the compression, then there is no need to upgrade the pistons. Just some things to think about.
Don't forget:
Head work
Cams -- JUN, Toda, Skunk2
Intake manifold -- Skunk2
Throttle body -- Type-R, Spoon
Old Jun 27, 2002 | 08:46 AM
KC GSR's Avatar
Default Re: GSR Enginge Internal Aftermarket Products (BSQ)
are the OEM rings and bearings suitable for a turbo buildup?
Old Jun 27, 2002 | 09:05 AM
X2BOARD's Avatar
Default Re: GSR Enginge Internal Aftermarket Products (KC GSR)
k20dreamSI
Oct 20, 2009 10:19 PM
POE
Apr 19, 2005 09:03 PM
chet
Feb 2, 2003 06:52 PM
