new to importationism
Old Dec 13, 2007 | 01:29 PM
mav87's Avatar
Default new to importationism
have a 96 civic hatch. 1st and most unimportant is where is the obd2 dlc and 2nd is with all these bolts ons, do they bolt straight up the the trans? i been looking at a b18 for my civic cuz there happens to be so many at the junk yard. is there a link or something that could lead me to more info on that? do i need to move mounts around or do any welding or drilling? would my stock manual trans be ok with it?
BIG QUESTION! if u dont want to reply to any of that bs up top just answer me this. my clutch was slipping and had very little play of engagement/disengagement so i put a clutch in it and it doesnt slip at all but it feels like a racing clutch, has like 1 inch of play in it. the fork moves according to the clutch pedal movement so its a problem after the fork, any hints, tips or anything would be awesome. if u just read all this and want ur 2 minutes of life back, im sorry
Old Dec 13, 2007 | 01:36 PM
Malakai's Avatar
if ur looking at a b18b ls motor, its a direct drop in with a few required parts such as axels, half shaft, and a rear t bracket from a 99-00 si. along with the ecu of course.
correct boys?
Old Dec 13, 2007 | 01:37 PM
pearlcfcivic97's Avatar
Default Re: new to importationism (mav87)
https://honda-tech.com/zerothread/878010
your going to have to read on your own for awhile before anyone is going to answer your questions considering how broad they are...
I dont understand what exactly the problem is with your clutch it sounds fine to me, you just dont like how it feels? I might not understand what your asking tho
read the links at the top of the honda civic thread that are stuck at the top most of them are FAQ you find most answers there...
Old Dec 13, 2007 | 01:44 PM
mav87's Avatar
Default Re: new to importationism (pearlcfcivic97)
i drive for a living i think i know how a clutch is supposed to feel. its not supposed to have all its engagement within 1 inch of pedal movement. i already did a pedal adjustment its not that. its something after the fork i can see it move through the slave cylinder boot.
Old Dec 13, 2007 | 01:54 PM
It sounds absolutely fine to me, what kind of clutch did you install?
Old Dec 13, 2007 | 02:13 PM
NOFX's Avatar
H-T White Ops
The data port is on the driver's side near the fuse box and hood pop.
Old Dec 13, 2007 | 06:07 PM
mav87's Avatar
Default Re: new to importationism (NOFX)
hell yea i adjusted clutch pedal to spec and it didnt help so i adjusted the pushrod all the way out and it works perfect now. i found that dlc too right above the foot rest. by the fuses thanks =D
kallmijonx2
48
May 2, 2010 08:36 PM
that one guy
Honda Motorcycles
Jun 28, 2006 11:11 PM
bonstokLS
11
Mar 20, 2006 04:28 PM
94ls
Sep 29, 2004 08:17 AM
ragejed
Jul 20, 2002 03:45 AM
