How to Wire a Boost gauge
most boost guages just use a vacume line and any wires would be for lighting if you have an electric one it probably requires some sort of sending unit for a decent anwser you need to say what model your guage so someone with a similar one can chime in
put your positive into your lighting fuse slot. i think its a 15amp. and then bolt the negative to something metal on the car.
