ls ecu in d16y7
It will run a much more agressive fuel map, and you'll run rich.
Yes it does make a difference, im not going to type up the argument of why.
I have credible proof, PM me if you would like to see it.
Check engine lights, will run like ****, etc. etc.
Usually the IACV will toss out a code due to the different IACV type on an LS engind and a 96-00 Civic.
It also would run very rich causing "system too rich" codes as well.
Not a good idea.
Not a good idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyek9 »</TD></TR><TR><TD CLASS="quote">so it would be a very bad idea to do it .. what can i do to make my d16y7 faster but quick .. </TD></TR></TABLE>
It would be a bad idea for OBD2 y7's. In an OBD1 car with a few things altered, thats a different story.
As for the y7, there are a few immediate things that would give it a little more go. Things like a lightened flywheel, EX tranny would make a very nice and noticible difference. You can also consider intakes/header/exhaust, but the fact is that its a singlecam, and the only way your going to get some power out of it is with forced induction.
exare250
Aug 16, 2005 03:46 AM
