Battery Light
Old Dec 13, 2007 | 07:53 AM
Malakai's Avatar
Default Battery Light
98 dx
d16y7
Hey all, just left for work this morning, -18 celcius, 0 fahrenheit. And when i went to start the car, it started but was chugging like it was running on 3 cyl. Car was fine last nite no probs.
When i upped the rpm's, it smoothed out. Well i had to get to work so i drove it as is. Just as im almost there i get to a stop sign and the car dies. I get it started again and it just dies again. If I keep the RPM's up it will stay running, but as soon as I let off it dies. There is no CEL.
Im thinking my battery is dead, but I just bought a new one like 2-3 weeks ago.
The only thing i did recently was give a friend a boost and I'm thinking thats what killed the battery.
Any ideas people?
Thanks.
Old Dec 13, 2007 | 08:53 AM
Malakai's Avatar
bump....
No one has any suggestions?
Old Dec 13, 2007 | 09:03 AM
WhiteOnRice's Avatar
Do your lights dim?
Old Dec 13, 2007 | 09:08 AM
Malakai's Avatar
Naw.
Just wont run on its own. I have to hold on the throttle to keep the revs up. Im pretty sure the battery took a **** from the boost.
But i just wanted some other opinions.
Old Dec 13, 2007 | 10:00 AM
eg6itr069's Avatar
Default Re: (Malakai)
it might be your alternator...
Old Dec 13, 2007 | 10:04 AM
keviiinnnnn's Avatar
Default Re: Battery Light (Malakai)
id check your alternator thats your best bet if you just bough a new battery not to long ago
Old Dec 13, 2007 | 10:19 AM
eg6itr069's Avatar
Default Re: Battery Light (keviiinnnnn)
yeah that is my best bet...the alternator is not charging your battery well enough...so if you can go out an see if someone could check your alternator for you to see if it good or not..
Old Dec 13, 2007 | 10:24 AM
blk92_d16's Avatar
The bad alternator hasn't been charging the "new" battery, so its got no charge. Take both to AutoZone or where ever to get them tested ASAP. Where did you get the batt cuz the alternator "could" have ruined the batt.
Old Dec 13, 2007 | 11:29 AM
Malakai's Avatar
well the battery is still under warranty so ima exchange it. If this still happens then i know its the alt. If it was the alt would the car still run if i give it throttle? cause if it was running on just battery then it would die right? Cause it still runs if i keep the revs up.
Old Dec 13, 2007 | 11:32 AM
fmrprojects's Avatar
its the alternator. get a new battery and check what voltage you get at the battery when idle if less than 13.8V your alternator is not charging the battery
Old Dec 13, 2007 | 12:19 PM
Malakai's Avatar
K, ill give that a shot!
Odd thing tho, i went for lunch and the car is idling like normal. Doesnt sound like its running on 3 cylinders anymore and doesnt stall out?
What do u think is up?
Old Dec 19, 2007 | 10:37 AM
hatch96y7's Avatar
fist if ur car is not staying on when u drive it it isnt ur battery.
the alt is what keep ur car on.
to check ur alt.
start the car and disconnect the pos bat cable and if the car dies right away then ur alt is toast if it stays on then u got another problem.
start checking ur bat fuse under ur hood .,
then ur alt spped sensor fuse under ur dash.
ur battery is mainly to start your car.
Old Dec 19, 2007 | 11:18 AM
Malakai's Avatar
thanks for the reply. I think i have narrowed it down to a faulty MAP sensor, as i have a cel #3 now. The Alt and battery voltage checked out.
busha61067
Feb 10, 2010 04:54 PM
shawndb1
Apr 4, 2009 09:10 AM
92civic_hatch
Feb 6, 2009 06:02 PM
kylemiller123
Dec 14, 2008 04:38 AM
samdawgsol
Apr 3, 2005 12:02 AM
