help car runs out of gas at 1/2 tank
Old Dec 12, 2007 | 09:43 PM
djicon2000si's Avatar
Default help car runs out of gas at 1/2 tank
i recently burned out my oem fuel pump, so i replaced it with a walbro fuel pump. it started out thats i would run out of gas when my gauge said 1/4 tank... but last week it ran out at 1/2 tanks of gas... all i do is run to the gas station buy $5 in gas put it in the car then everything is fine... i know my gauge isnt broke because it would only cost $10 to fill the tank... now my car is at 3/4 and its "out of gas"... please help... im thinking bad fuel pump, bad wiring, bad fuel cut off switch, bad ground... any feedvack would be greatly appreciated
Old Dec 12, 2007 | 10:03 PM
fmrprojects's Avatar
Default Re: help car runs out of gas at 1/2 tank (djicon2000si)
your strainer might have fell off the fuel pump
Old Dec 12, 2007 | 10:41 PM
PinoyDelSol's Avatar
* B A N N E D *
Default Re: help car runs out of gas at 1/2 tank (fmrprojects)
Did you make your own custom fuel kill switch?
Old Dec 12, 2007 | 10:48 PM
fullraceacura's Avatar
the first place to start is always, ALWAYS with the most recent thing that has been changed before it started ******* up,
for example the fuel pump or your fuel cut off wirering, or the wires on the fuel pump that you just put on maybe something didnt get a secure connection, something is malfuntioning
Old Dec 13, 2007 | 11:18 AM
blk92_d16's Avatar
Unfortunately as well, Walbros do go bad too...but check the "sock filter", the grounds, and all connections.
Old Dec 16, 2007 | 11:07 AM
thanks ill check the strainer tomorrow morning...
91cb7h23
Feb 10, 2013 04:13 PM
drwoody
May 28, 2010 05:52 PM
traxxasx
Mar 16, 2010 10:21 AM
kaoss_11
11
Dec 9, 2004 08:29 PM
Propulsion
Jul 8, 2002 11:15 AM
