b16 eg, cold start problems....
yeah i got a b16 in my hatch, only mod is intake, but everytime i goto start the car in the morning, or even after sitting a while, if not overnite then like 3-4 hours.
it will start up, low rpm, like 100, yeah 100, not 1k! then it takes a while to warm it up, sounds like a muscle car, like only two valve engine, and every so often itll smoke for a lil bit, like whitish clear smoke. any ideas? i think it might be about time for my head gasket to be changed....
if i do change my head, should i change/replace anything else while its all apart?
White is more than likely antifreeze, so your right about the headgasket. As for the 100 idle lol, i dont know if the h/g would cause that if your only seeing a little smoke. Have you cheked your spark wires, firing order, and little things like that?
hondaless
Aug 4, 2004 01:03 PM
