MUGEN valvecover, GSR shortblock, B-series Dizzy VTEC, LS BLOCK, ECUs, Header, Injectors, Throttlebo
Old Dec 12, 2007 | 04:40 PM
Extradition's Avatar
Default MUGEN valvecover, GSR shortblock, B-series Dizzy VTEC, LS BLOCK, ECUs, Header, Injectors, Throttlebo
SOHC Mugen Valvecover (Brand New and RED): $120
2000 Si Clutch Master Cylinder: $40
1995 GSR short block (crankshaft, rods, pistons, girdle, oil pan, oil pickup, water pump, oil pump, tensioner, stock clutch): ENJOI UR MOTOR SIMPLETEG!
OBD1 (B-series) Alternator: $60
B-series Starter: $40
OBD1 (B-series, VTEC) Dizzy: $120
1996 LS block (bored to 82mm's): $80
1996 LS crankshaft: $80
1996 LS rods and pistons: $60
JDM GSR 4-2-1 header w/ heatshield: $100
OBD1 P0B Non-Vtec (F22B2 engine, Manual tranny) ECU: $60
OBD1 P06 Non-vtec (SOHC, Manual tranny): $60
OBD1 PR4 LS (DOHC, Manual tranny) ECU: $80
OBD0 PR4 LS (DOHC, Manual tranny) ECU: $50
Pre-OBD0 PG7 LS (DOHC, Manual Tranny) ECU: $40
JDM B16a (SiR-II) camshafts: $40
JDM B16a Intake Manifold and fuel rail: $50
JDM B16a Valves: $50
JDM SiR-G (B18C/GSR) camshafts: $70
JDM SiR-G retainers and valvesprings: $60
LS pistons and Rods (81 mms): $60
92-95 Honda Civic Heater Core: $50
92-95 Honda Civic Winshield wiper Motor: $40
92-95 Honda Civic Sedan rear corner lights (set): $40
92-95 Honda Civic Ignition w/ key and ignition harness: $60
92-95 Honda Civic Interior wiring harness (uncut): $100
92-95 Honda Civic Turn Signal switch: $30
92-95 Honda Civic High-beam low-beam switch: $30
92-95 Honda Civic/94-01 Acura Integra H-series HASPORT motor mounts (EGH1): $300
92-95 Honda Civic/94-01 Acura Integra Koni Orange struts and Eibach springs: $150
92-95 Honda Civic Hatchback Back seat windows: $30 each
92-95 Honda Civic 2-Door Passenger window: $50
Apexi VAFC (Grey) with harness and mounting stand: $120.00
95 JDM GSR throttle body: $25 (sensors extra)
98 USDM LS throttle body: $25.00 (sensors extra)
95 D16Z6 intake manifold with injectors and Throttle Body: $50.00
MSD Blaster SS coil (New): $20
Accel B-series Internal Coils (New): $40
**I'm also parting out a 1996 Honda Civic SEDAN (4-DOOR) DX; I have glass, doors, mirrors (non-power), window regulators, brake boosters, steering rack, interior panels, and a lot of other items including a right rear 1/4 panel. If you're interested in any parts, or ANY OTHER PARTS give me a call!
(951) 247-8018 JAMES : Leave a message if I don't answer!
PRICES ARE PICKED UP: KEEP THIS **** TO THE TOP HOMIES!
Modified by Extradition at 9:21 PM 12/16/2007
Modified by Extradition at 12:00 PM 2/21/2008
Old Dec 13, 2007 | 10:32 AM
Default Re: MUGEN valvecover, GSR shortblock, B-series Dizzy VTEC, LS BLOCK, ECUs, Header, Injectors, Thrott
Old Dec 13, 2007 | 10:36 AM
jdm_bones's Avatar
BUMP!
Old Dec 13, 2007 | 12:10 PM
95ProjectEJ1's Avatar
BUMP this
Old Dec 13, 2007 | 04:50 PM
Thanks for the BUMPS!
Old Dec 13, 2007 | 07:21 PM
Old Dec 13, 2007 | 10:36 PM
Old Dec 14, 2007 | 04:50 AM
Old Dec 14, 2007 | 06:35 AM
mannyman2's Avatar
does it have us vin plate on motor???? gsr
Old Dec 14, 2007 | 09:01 AM
The motor is a 1995 GSR motor, which never came with a vin plate; they started putting Vins on the motors in 1996+. LMK if you're interested.
Old Dec 14, 2007 | 04:19 PM
Old Dec 14, 2007 | 06:18 PM
Old Dec 14, 2007 | 11:14 PM
Old Dec 15, 2007 | 07:48 AM
Old Dec 15, 2007 | 12:10 PM
Old Dec 15, 2007 | 02:30 PM
Old Dec 16, 2007 | 07:37 AM
Old Dec 16, 2007 | 05:33 PM
eg6typeRbeeotch's Avatar
Banned
Old Dec 16, 2007 | 08:23 PM
Old Dec 17, 2007 | 08:08 AM
Old Dec 17, 2007 | 09:44 AM
Old Dec 17, 2007 | 04:53 PM
Old Dec 17, 2007 | 06:07 PM
Old Dec 17, 2007 | 08:53 PM
Old Dec 18, 2007 | 08:41 AM
