Swapping My Teg into a civic...in a way
Old Dec 12, 2007 | 02:44 PM
dc2matt's Avatar
Default Swapping My Teg into a civic...in a way
Hey all, i've searched a lot and read up on a lot of **** i will need to do a b18b swap into a 96-99 ej. I have my complete integra, daily driver, '94 integra w/ GSR Tranny, but one problem, the body is going to ****. I found a 99 civic ex with 230k on the motor i can get real cheap. It is a 99 EX auto. I want to take my rear discs (trailing arms, ect all that ****), Motor, Tranny, ECU, suspension etc. I want to know about the whole OBDI swap problems (i'm not sure if there will be seeing a sim using my ecu, and dizzy, etc), also with the wiring, do i have to yank the whole wiring harness out of my teg? Another thing is the manual swap, i've read into manual swaps and it doesn't seem to difficult with all the parts. I was wondering if most of the parts from my teg will fit in the civic. (Shift linkage, shifter, pedals, cylinders) Also will the motor mounts from my teg now bolt up to the civic chassis. I might have confused some people, but let me know if you have any input, or have some links that i might have missed.
Old Dec 12, 2007 | 02:47 PM
HAMOTORSPORTS's Avatar
Default Re: Swapping My Teg into a civic...in a way (dc4matt)
in brief:
you need ek b series mounts (99-00 si)
you need to modify the top trans munt bracket
there is plenty of info here on the wiring just search
best of luck
Old Dec 12, 2007 | 02:51 PM
db8db8db8's Avatar
Did you already hit up the NEW FAQ's thread at the very top of this forum? Im sure everyone will have plenty of input on this topic but the FAQ's thread should also be very helpful and self explanitory.
Old Dec 12, 2007 | 02:52 PM
dc2matt's Avatar
will all the tranny linkage and pedals and such work from my teg into the civic
Old Dec 12, 2007 | 03:19 PM
Malakai's Avatar
shift linkage is needed from the teg. cant say bout the pedals n stuff.
Old Dec 12, 2007 | 03:25 PM
dc2matt's Avatar
ok my next question, i am using the B18b ODBI ECU, into a civic with a OBDII harness. Do i need the conversion plug for the OBDII harness to the OBDI ECU, Change the IACV Plug, Injector Plugs, IAT Plug, Dizzy Plug, Alternator Plug. Anything i'm missing
Old Dec 13, 2007 | 08:12 PM
dc2matt's Avatar
bump for extra info
Old Dec 13, 2007 | 09:03 PM
p nut's Avatar
I believe that the rear suspension will not bolt up to the 96+ Civics. The LCA's are longer on the EJ, I believe.
Can you not find an Integra shell? I'd rather pay a little bit more and get that instead of the Civic.
Good luck with the swap.
Old Dec 13, 2007 | 09:44 PM
jasony0630's Avatar
76.26.106.124
the only thing i know about your issue is that you will need the rear tranny mount and blockside driver side mount from your teg (i think its the driver side...cant remember right now) you'll also need your shift linkage from the teg, and axles for the swap.
and also im not sure if teg suspension bolts up to the civic, if it does, it will sit kinda high.
the only reason i kinda know b series swaps into automatic ek's is cuz im doing one right now. 1999 civic ex automatic getting a b16a3 from a del sol dohc vtec witha 5 speed conversion.
hope that helps
Old Dec 14, 2007 | 05:44 AM
b18bye's Avatar
Default Re: (p nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p nut &raquo;</TD></TR><TR><TD CLASS="quote"> Can you not find an Integra shell? I'd rather pay a little bit more and get that instead of the Civic. </TD></TR></TABLE>
X2 alot less work and money in the long run .
Old Dec 14, 2007 | 05:53 AM
BryanM.'s Avatar
Resident Gearhead
Teg rear trailing arm won't just "bolt up", Civic drivers side eng mount is different than the Tegs get one from a 99-00 Si or form HASport and you need to convert to OBDI.
Old Dec 14, 2007 | 07:17 AM
dc2matt's Avatar
for the rear suspension, i want to do the disc brake conversion, and use my sportlines, not the LCAS, and all that ****
Old Dec 14, 2007 | 09:10 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: Swapping My Teg into a civic...in a way (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">Teg rear trailing arm won't just "bolt up", Civic drivers side eng mount is different than the Tegs get one from a 99-00 Si or form HASport and you need to convert to OBDI.</TD></TR></TABLE>
Excuse me, I need to correct myself. You will need all mounts from a 99-00 Si or HASport.
Old Dec 14, 2007 | 12:21 PM
superd16girl's Avatar
Yup the body is definetly going to ****! haha
Old Dec 15, 2007 | 04:51 AM
dc2matt's Avatar
just like your motor super16girl hahaha
dc2matt
Dec 18, 2007 01:10 PM
92h22civichatch
Northeast (Sales)
Jul 17, 2007 05:58 PM
gwegcivic
Apr 23, 2006 12:07 AM
Civic_EX_turbo
Jan 21, 2004 02:36 PM
