b18b swap
b18b swap
so im about to do a b18b swap into my eg within the next month. When i do it i plan on doing the auto - manual conversion as well. I have come across a couple of motors one is from a 95 teg and the other is from a 99 teg. I was kinda leaning towards the one out of the 99 teg just because it will have less km's on it but then i also realized that it was 300 bucks more. My question is how much of a hassle will it be to put the 99 teg motor in as compared to the 95 teg motor? is it worth the extra money?
I am planning on doing a ls/vtec set up eventually. So should i just save the 300 bucks and put towards a new head? And what other parts am i going to need to do a stock ls/vtec i have come across a few kits on egay but not sure if they are all i need. here is a link. Any help would be great
http://cgi.ebay.ca/LS-VTEC-FUL...wItem
Re: b18b swap (B16aDasher)
yes the distributor is included on the 99.. how much are hte jumper harnesses usually.. and what else will have to be changed?
Re: b18b swap (gwegcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gwegcivic »</TD></TR><TR><TD CLASS="quote">yes the distributor is included on the 99.. how much are hte jumper harnesses usually.. and what else will have to be changed?</TD></TR></TABLE>
You may be able to find it cheaper, but rywire as them for 75 us dollars. Converting to obd1 is the best choice IMO, then you can run uberdata later on. Tuning is going to be important on that ls/vtec.
http://rywire.com/store/produc...7351d
Yeah but how many km difference are we talking about on each motor?
I'd have to concur, converting to ODB1's better in my opinion, but then again, what's the km's on that one oppose ot the 99 engine?
Well most cars are in junkyards because they were in accidents and are totalled out.....that's just a concensus of MOST cars in junk yards, not all....
Still, check the km's on them...
Re: (Syndacate)
the 95 teg has bout 140km on it and the 99 teg has about 100 km on it. If i were to do the lsvtec would the kit that i found on ebay work for me.. then i would just need a b16 head adn ecu?
Re: (gwegcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gwegcivic »</TD></TR><TR><TD CLASS="quote">the 95 teg has bout 140km on it and the 99 teg has about 100 km on it. If i were to do the lsvtec would the kit that i found on ebay work for me.. then i would just need a b16 head adn ecu?</TD></TR></TABLE>
There is alot of good info on honda-tech.
these links will help too.
http://sportcompactcarweb.com/tech/0411scc_hybrid/
http://www.c-speedracing.com/h...c.php
Re: (B16aDasher)
thanks for them sites they helped alot concerning the lsvtec but now i still need to know what i need to put the 99 teg motor in over the 95 teg motor.. as well what axles do i use? can i use integra axles.. the car is a 94 civic cx
dc2matt
14
12-15-2007 04:51 AM
