Do YOU remember the order to follow for bleeding your brakes?
Old Jun 27, 2002 | 04:57 AM
Turtle's Avatar
Default Do YOU remember the order to follow for bleeding your brakes?
I was bleeding my brakes last night and forgot the dang order!
Old Jun 27, 2002 | 05:00 AM
Doctor CorteZ's Avatar
Default Re: Do YOU remember the order to follow for bleeding your brakes? (401-2001)
furthest away first
right rear
left rear
right front
left front
double check
I usually do it twice just to be sure
[Modified by Doctor CorteZ, 2:01 PM 6/27/2002]
Old Jun 27, 2002 | 05:09 AM
Turtle's Avatar
Default Re: Do YOU remember the order to follow for bleeding your brakes? (Doctor CorteZ)
EEEEERRRRRRNNNNNNTTTT....incorrect. Next. (PS This is what I thought until I was corrected myself last night )
Old Jun 27, 2002 | 05:11 AM
Willard's Avatar
Next = it does not matter which way you do it.
Will
-who has done every combination... with no ill effects
sackdz's Avatar
ERRRRRRRRRRRRRNNNNNNNNNNNNNNNNT It doesn't matter.
Old Jun 27, 2002 | 05:12 AM
Willard's Avatar
Default Re: Do YOU remember the order to follow for bleeding your brakes? (sackdz)
JINX!
sackdz's Avatar
Default Re: Do YOU remember the order to follow for bleeding your brakes? (Willard)
Old Jun 27, 2002 | 05:22 AM
Dave-ROR's Avatar
The manual probably says: RR, LR, RF, LF or RR, LF, LR, RF. But like Will and Sackdeeznutz said, it doesn't really matter.
Old Jun 27, 2002 | 05:23 AM
Dr Pooface's Avatar
According to the current manual they want you to start at the left front and work your way around clockwise. But I have seen an earlier manual where starting at the right rear was the way to go. it doesn't really matter where you start, but I wonder why Helms changed the order.
Turtle's Avatar
LOL...ok now I'm getting flamed. I thought that is was supposed to be in this order. (This is what worked also).
1 = Rear Driver's Side
2 = Front Pass Side
3 = Rear Pass Side
4 = Front Driver's Side
I wasn't trying to knock on anyone, really
Old Jun 27, 2002 | 05:24 AM
ITR764's Avatar
Default Re: Do YOU remember the order to follow for bleeding your brakes? (Garth vadeR)
RR, LF, LR, RF
this is the order i used and my pos still stops.
Old Jun 27, 2002 | 05:25 AM
Dave-ROR's Avatar
2 = Front Pass Side
3 = Rear Pass Side
same as RR/LF/LR/RF.. the theory on that method is that you bleed each cross line first (RR/LF are "connected" and LR/RF are "connected")
I personally like to start at the master cylinder
Old Jun 27, 2002 | 05:51 AM
Turtle's Avatar
Has anyone used the old "gravity bleed" method? Does it work well? And who all has speed bleeders? Are they truely one man.
[Modified by 401-2001, 9:52 AM 6/27/2002]
Old Jun 27, 2002 | 05:54 AM
ILUVTEC's Avatar
Listen, there is somewhat a meaning to the madness of what order to bleed the brakes(cross-bleeding, starting furthest away, working clockwise around, etc.), BUT in reality it really does not matter that much(this is also why many different manuals say different things about the same car). I know many many honda techs that work at a few different dealership shops and when it is necessary for them to bleed the brakes, they usually do not follow a set pattern because they know that it really does not matter. This is true, but if you follow a pattern, which I try to most of the time, then that is fine too because again it really doesnt matter. Just figured I shed a bit of light on this subject, just do what makes you feel best, or what may happen to make your brakes feel the best(if it happens to work better for them one way or the other, which could happen, but not usually), enjoy.
Old Jun 27, 2002 | 05:55 AM
Back in Black's Avatar
Rather OG
And who all has speed bleeders? Are they truely one man?
They own, and make bleeding truly a one man job. Of course, that's assuming you're not too lazy to check the resevoir every now and then
[Modified by Jason Franza, 9:56 AM 6/27/2002]
Old Jun 27, 2002 | 08:05 AM
electronspeeder's Avatar
Default Re: Do YOU remember the order to follow for bleeding your brakes? (Jason Franza)
Gravity Bleed.
Old Jun 27, 2002 | 08:30 AM
GRM Scott's Avatar
25 Year Member
speedbleeders, one-manned them several times. I use the helm order, LF, RF, RR, LR...but agree it doesn't matter
Old Jun 27, 2002 | 09:19 AM
learn something everyday
always heard farthest first, oh well
change noted in my "little book"
Old Jun 27, 2002 | 11:37 AM
Ausmith's Avatar
I always went longest to shortest....
Are the ITR brakes on a "fail-safe" crossed line? (LF and RR on same line)? If so, then the those brakes should be bled together longest to shortest.
whatan00b
Sep 2, 2006 03:27 PM
Mavrick
Oct 10, 2005 08:52 AM
TSAngry
Apr 27, 2005 05:01 PM
from_zer0
14
Dec 11, 2004 03:40 PM
see_fu
Sep 10, 2002 10:37 PM
