Suspension & Brakes Theory, alignment, spring rates....
aftermarket shock forks ?
Old Dec 12, 2007 | 11:24 AM
DaveF's Avatar
Default aftermarket shock forks ?
just did a quick search on here came up with a whole lot of nothing.
my question is..
are there any companies that produce taller shock forks for 92 + civic's ? (1 inch taller preferebly)
my dilema is that i have a lowered spindle on the car, so the axle touches the shock fork. ...
Old Dec 12, 2007 | 01:28 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: aftermarket shock forks ? (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">just did a quick search on here came up with a whole lot of nothing.
my question is..
my dilema is that i have a lowered spindle on the car, so the axle touches the shock fork. ... </TD></TR></TABLE>
well I've been around the sport compact scenes, Hondas, etc. for nearly 12 years and I've never seen taller front forks. I've seen the ST shortened front forks but those didn't last very long and are pretty hard to find these days.
Where did you get lowering spindles from?
Old Dec 12, 2007 | 02:22 PM
Tyson's Avatar
Default Re: aftermarket shock forks ? (PatrickGSR94)
interesting request... never heard of this, probably because ive never heard of lowering spindles before and never thought of the implication on axle position.
try looking at other vehicles, like preludes, accords, or legends for taller forks.
Old Dec 12, 2007 | 03:18 PM
Community Builder
Default Re: aftermarket shock forks ? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">interesting request... never heard of this, probably because ive never heard of lowering spindles before and never thought of the implication on axle position.
try looking at other vehicles, like preludes, accords, or legends for taller forks.</TD></TR></TABLE>
A lowering spindle would move the hub position up higher in relation to the upper and lower ball joints, which would cause the same issues if you use the fork trick on Konis to lower your car, where if you slide the forks up too high the axle will hit the bottom of the shock body.
Old Dec 12, 2007 | 04:45 PM
DaveF's Avatar
the lowering spindles are from http://www.nitrodriveline.com
Modified by DaveF at 8:56 PM 12/12/2007
Old Dec 12, 2007 | 05:09 PM
Tyson's Avatar
interesting...
have you asked them yet?
Old Dec 12, 2007 | 06:38 PM
BlueIntegraBoy's Avatar
Wow, that looks pretty amazing.
Old Dec 13, 2007 | 02:24 AM
DaveF's Avatar
the guy who fabricates those (Fabman on here) is making me some taller forks..
i want to know if there are any other companies/people or maybe even an oem fork that are taller than the oem on ... say a 94 integra.
Old Dec 13, 2007 | 07:44 AM
Community Builder
Most likely you would just have to do custom lengthened forks, where you cut each leg of the fork and weld material in between each piece.
Old Jan 15, 2008 | 12:56 PM
DaveF's Avatar
Default Re: (PatrickGSR94)
Here they are
Old Jan 15, 2008 | 02:28 PM
Community Builder
I would think that longer forks would defeat the purpose of the drop spindles - raising the ride height of the car back up.
Old Jan 15, 2008 | 02:57 PM
Tyson's Avatar
seems like a necessary tradeoff. just use shorter sleeve over springs and extended top hat. then it wont matter.
with the top fo the fender being the real limiting factor, youre just moving things around, giving and taking.
Old Jan 15, 2008 | 03:04 PM
DaveF's Avatar
Default Re: (Tyson)
we had to use the taller fork because the axle was touching the bottom side of the oem fork.
i used to run a 10inch tall coil spring, and now went to an 8inch tall coil spring.
also i went to an oem top hat(from an aftermarket billet top hat) which allows the shock to have a bit more travel, and not bottom out.
Old Jan 15, 2008 | 06:10 PM
highroller54's Avatar
Default Re: (DaveF)
how much does that lower the car? Are you running the 930 c.v.'s?
Old Jan 16, 2008 | 02:35 AM
DaveF's Avatar
Default Re: (highroller54)
the drop spindles are 2inch's lower from oem hight. we use a 930 style cv.
here is a comparison shot
uglyasscivic
Oct 23, 2008 05:14 PM
hondachris1994
Feb 23, 2008 07:36 AM
CardDealer
13
Dec 5, 2006 06:48 PM
Arsenal
Sep 12, 2005 10:31 AM
improvdub
Mar 3, 2004 05:34 AM
