Clusters with a tach vs. no tach
Old Dec 12, 2007 | 04:53 AM
davefromPA's Avatar
Default Clusters with a tach vs. no tach
my setup. 94 cx hatch with lx engine. im wondering if i can bolt the cluster from the lx (with tach) into where my cluster is (no tach). will the tach work?
Old Dec 12, 2007 | 04:59 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: Clusters with a tach vs. no tach (davefromPA)
Yes the tach will work as long as the cluster is from a 92-95.
Old Dec 12, 2007 | 05:53 AM
slo_hatch's Avatar
plugs straight in...swapped my cx cluster with si cluster...10 min of work.
Old Dec 12, 2007 | 06:15 AM
Toroke's Avatar
Default Re: Clusters with a tach vs. no tach (slo_hatch)
Yup, plugs right in. Just be careful getting that bastard bezel off. If you've never done it before, be careful. There's a hidden screw. It's either by the clock or the hazard button, I forget which one. You take one of those out and can see it.
Old Dec 12, 2007 | 06:58 AM
Syndacate's Avatar
Default Re: Clusters with a tach vs. no tach (Toroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toroke &raquo;</TD></TR><TR><TD CLASS="quote">Yup, plugs right in. Just be careful getting that bastard bezel off. If you've never done it before, be careful. There's a hidden screw. It's either by the clock or the hazard button, I forget which one. You take one of those out and can see it.</TD></TR></TABLE>
2 screws in the bezel above the cluster, one behind the hazzard switch.
It doesn't really matter if you break ALL of the tabs off the bezel - it'll still seat back in fine. Just remember to unplug the clock, the hazzard switch pops right out to gain access to the screw.
Then there's 4 screws in a square formation that hold the cluster in - then 3 (I think 3) plugs in the back.
The cluster's in '92-'95 civics are plug and play. You can just plug in the LX/EX/Si cluster and it'll work fine - the wiring already exists for the tachometer.
Old Dec 12, 2007 | 08:08 AM
baller status's Avatar
Default Re: Clusters with a tach vs. no tach (Syndacate)
VX's also have a tach.
Stay away from JDM tachs because they're listed in km/h not mph.
Old Dec 13, 2007 | 08:17 AM
davefromPA's Avatar
thanks guys. ill be doing that next week. its a USDM model so i dont have to worry about kph
Old Dec 13, 2007 | 08:36 AM
homemadeturbo's Avatar
Default Re: Clusters with a tach vs. no tach (baller status)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baller status &raquo;</TD></TR><TR><TD CLASS="quote">VX's also have a tach.
Stay away from JDM tachs because they're listed in km/h not mph.</TD></TR></TABLE>
You mean a whole JDM cluster? Because a tach is in rpm which is the same in SI or standard units.
Old Dec 13, 2007 | 08:38 AM
.:Swig:.'s Avatar
put in a gsr cluster
Old Dec 13, 2007 | 10:05 AM
davefromPA's Avatar
Default Re: Clusters with a tach vs. no tach (.:Swig:.)
got any pics of one? a gsr cluster? something that will bolt right into my 94 civic
Old Dec 13, 2007 | 10:12 AM
.:Swig:.'s Avatar
https://honda-tech.com/zerothread?id=1470686
https://honda-tech.com/zerothread?id=1053318
94-01 teg cluster into 92-00 civics
http://www.geocities.com/cinq1....html
94-98 teg cluster into 92-95 civics
Old Dec 13, 2007 | 10:20 AM
davefromPA's Avatar
thanks dude. ill see what i can pull in the way of a gsr cluster now
Old Dec 13, 2007 | 10:21 AM
.:Swig:.'s Avatar
yep no problem, i had no tach either for my 00 ek and i always put a gsr cluster in my civics. I just love they way they are setup. good luck
BridgeSVT
Oct 27, 2007 07:29 PM
djaiew
Dec 7, 2006 04:52 PM
WhiteOnRice
Aug 18, 2006 10:31 AM
WhiteOnRice
Aug 12, 2006 12:02 PM
FifthGearOnline
Mar 28, 2002 05:09 AM
