starting in cold weather
when it drops to about 30 my car has a really hard time starting, it used to sputter and start then run fine. but now it is not even firing at all
mine does that too every now and then
you using water or actual coolant?
might be that the water pump is breakign up the frozen water when starting up
doh
hopefully not
i havent really done anything with my coolant for a while, but i know i was filling it up in the summers with water -_-
hopefully noti havent really done anything with my coolant for a while, but i know i was filling it up in the summers with water -_-
you might need a new battery. trun on your head light for like 10-15 sec then turn them off before you try to start your car. and go to the auto parts store and have them test your battery. they should test it 4 free
its cranking strong, but it just doesnt fire. all the lights work fine and my fuel pump primes up good.
ive been cranking it for a bit but i still get nothing.
it def is getting air, and i can smell the gas in my exhaust...
so my guess is spark
is there any reason it wont spark when it gets cold?
no i dont really have any tools im at college
but i did have a screwdriver and i took the cap off my dizzy, the rotor is burnt black and the cap has grooves where it touches the rotor that are burnt black also
so im going to go change that
i was thinking about the main relay, i already checked the fuses under the hood, they are all there, or at least the ones with the clear tops on them they are still good. my fuel pump primes and im pretty sure i hear a click. but i can go double check.
if my pump primes and my car cranks, could it still be the main relay?
willpower102
Jan 22, 2013 12:44 PM
