94-95 pass airbag dash into 92-93
Old Dec 11, 2007 | 09:24 PM
CapnKrunch's Avatar
Default 94-95 pass airbag dash into 92-93
I searched but found nothing... Will the 94-95 civic dash with the passenger airbag be able to swap into a 92-93 civic without the pass airbag? I'm guessing you may have to remove the air bag to make it fit into the 92-93?
Old Dec 11, 2007 | 09:27 PM
sleepyH22's Avatar
dude...remove ur 92-93 dash... Install the 94 or 95 dash WITH THE pass side airbag, no it wont be functional but itll look oem...if u want it to work..then you'll need the dash harness from the 94-5
Old Dec 11, 2007 | 10:02 PM
CapnKrunch's Avatar
Default Re: 94-95 pass airbag dash into 92-93 (CapnKrunch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyH22 &raquo;</TD></TR><TR><TD CLASS="quote">dude...remove ur 92-93 dash... Install the 94 or 95 dash WITH THE pass side airbag, no it wont be functional but itll look oem...if u want it to work..then you'll need the dash harness from the 94-5</TD></TR></TABLE>
Ok, I didn't know for sure that it would fit with it in. But the airbag can be functional w/ the 94-95 harness? I was just planning on deleting the airbag anyway though with the passwordjdm carbon kevlar airbag delete tray.
redboost10
Aug 10, 2006 01:48 PM
mountaindewguy
Oct 24, 2005 08:04 PM
importracer47
May 7, 2003 06:09 PM
