need tourqe specs for a b16
Here you go, noob.
Tighten the cylinder head bolts in two steps. In the first step, tighten all bolts in sequence to about 29 Nm (3.0 kgs.cm, 22 ft.lbs.). In the final step, tighten in the same sequence to 83 Nm (8.5 kgs.cm, 61 ft.lbs.).
