JDM distributor/wiring help!
Old Jun 26, 2002 | 10:52 PM
clemens's Avatar
Default JDM distributor/wiring help!
the jdm type r distributor has a different plug (just one). im using a gsr wiring harness(from a 1995 and has 2 plugs). how do i make this work? thanks
Old Jun 26, 2002 | 11:57 PM
salbaje's Avatar
Default Re: JDM distributor/wiring help! (clemens)
hit me up i can help you
Old Jun 27, 2002 | 01:12 AM
Kamin's Avatar
oook.
these are the minimum requirments for postinga question.
we cant help you unless we know these things.
1) what car do you drive
2) what year
3) what motor
4) what ecu
im gUESSING its an R motor in an obdI teg.
Old Jun 27, 2002 | 07:52 AM
clemens's Avatar
Default Re: JDM distributor/wiring help! (KAMiN)
soweee, i thought i put all the info, here it is:
-93 dx civic hatch
-jdm type r motor
-using a gsr('95, obd1) wiring harness
-ecu from sohfast (i think its p28) reprogrammed to R spec
thanks!
Old Jun 27, 2002 | 08:03 AM
sgT's Avatar
sgT
in 96 honda combined the two plugs into one.
it would probably be easier if you got a 92-95 distributor. or you can just
repin the one you have.
Old Jun 27, 2002 | 08:20 AM
clemens's Avatar
Default Re: JDM distributor/wiring help! (sgT)
so w/c distributor do i need, the one for gsr or i can just use the one from the civic dx?
-how do i repin since the colors are different compared to the gsr harness? the lower portion of it (2 wires) are easy to swap since the colors are the same but the top portion are different. thanks
Old Jun 27, 2002 | 08:23 AM
sgT's Avatar
sgT
The colors should be the same.
If you want to swap distributors, you will want to get a 92-95 gsr or del sol vtec
OhMy-EK9
Apr 24, 2012 09:56 PM
greddy2smoke
Jul 16, 2007 08:51 AM
greddy2smoke
Jul 16, 2007 08:50 AM
dkboyny11
Aug 10, 2006 11:29 AM
PNPFLIPPED
Jun 19, 2006 07:55 PM
