Rear Integra 4 Dr seat fit into 2 Dr ??
Old Jun 26, 2002 | 10:32 PM
Grandprix's Avatar
Default Rear Integra 4 Dr seat fit into 2 Dr ??
I noticed my buddy's four door has a normal back seat, where the two door has a plasting thing in the middle. Can the 4 dr seat be bolted into the 2 dr??
Old Jun 27, 2002 | 03:51 PM
Grandprix's Avatar
Default Re: Rear Integra 4 Dr seat fit into 2 Dr ?? (Grandprix)
up
Old Jun 27, 2002 | 09:10 PM
ee-gsr's Avatar
my guess is no because the DB8 actually gets wider from the front door back until the rear quarters.
not sure about the hooks, etc. that keep the 2 in place, but i assume they are different too.
it's a good bet that the JDM rear seats will not have that lil plastic tray (at least the JDM ITR rear seat doesn't have it).
Old Jun 27, 2002 | 09:26 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: Rear Integra 4 Dr seat fit into 2 Dr ?? (ee-gsr)
Nooo the back seats do NOT fit.. We tried this last week in my friends hatch with my gsr seats.. the fronts fit but the back does not.. the back is made to fold down for a trunk, not a hatch. The seat is too wide and there is nothing to keep it up because it does not latch..
Old Jun 28, 2002 | 12:01 AM
wickedik's Avatar
ok lets clear this up for you all. the 2 door (also considered a HB) integra front and rear seats fit in a EG hb with a small gap around the rear bottom cushion. the integra rear backs fit in the hb no problem. Although this may be hard to find, you should use the rear bottom from a 4dr integra and the rear backs from a 2dr integra to get the best fit. The 4 door integra seats fit perfectly into the 4door eg civic with the removal of the plactic cover under the rear dash. This most likely is the same for the 2dr also although you may want 2dr integra fronts and 4dr integra backs so thet you can have that foot lever on the back of the pasenger side seat. I've done this on a friends 4dr eg and it fit and looks good.
Old Jun 28, 2002 | 12:15 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
JDM ITR 2-door seats don't have the plastic thing, if that's what you want
Old Jun 28, 2002 | 09:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Honda put the plastic thing there because if they didn't, it would be classified as a 5-seater car, and they would be required to have provisions for a seatbelt for that middle seat. There wouldn't really be a good way to do that and still have the fold-down seats + hatchback as functional as it is.
Old Jun 28, 2002 | 11:21 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Rear Integra 4 Dr seat fit into 2 Dr ?? (wickedik)
wheew...that is hella confusing.
Old Jun 29, 2002 | 10:20 PM
Grandprix's Avatar
Default Re: Rear Integra 4 Dr seat fit into 2 Dr ?? (two.oh)
basically I just want to be able to lay down in the back seat and go to sleep. I dunno about importing a back seat from Japan...not worth the effort!
XooMZ
Mar 21, 2007 04:55 PM
93egryda
Oct 13, 2006 11:30 AM
93civicjaydm
Jul 12, 2005 10:22 AM
drive4aliving
Jul 5, 2005 04:18 PM
c for sea
23
Jan 2, 2005 09:55 AM
