rear seat differences
Old Jun 29, 2005 | 12:30 AM
drive4aliving's Avatar
Default rear seat differences
I bought a 96 LS 2 door and I believe it has maybe 99 rear leather seat.
the seat bottom doesn't seem to fit correctly, where the hook thing pushes into the body
the hole is in a different spot than the hook.
do I need 94-97 black leather seats then to fit correctly?
Old Jun 29, 2005 | 02:25 AM
jaydeemmmm's Avatar
Default Re: rear seat differences (drive4aliving)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drive4aliving &raquo;</TD></TR><TR><TD CLASS="quote">I bought a 96 LS 2 door and I believe it has maybe 99 rear leather seat.
do I need 94-97 black leather seats then to fit correctly?</TD></TR></TABLE>
I don't think you need 94-97 rear seats. They should all fit, except if it's a 4 door. Where the hook is suppose to latch onto might have been damaged due to excessive pushing and pulling of the seats.
Old Jun 29, 2005 | 04:07 AM
its not damage, the hook on the seat is in a totally different position from the hole its supposed to go into.
off by like 3 inches. I'm trying to get a picture of it
Old Jun 29, 2005 | 09:58 AM
7k rdlne's Avatar
Default Re: (drive4aliving)
i always thought all 94-01 2 door integra rear seats were the same and all 4 door 94-01 rear seats were the same.
Old Jun 29, 2005 | 10:08 AM
I thought so too, my first guess that maybe it was a 4 door seat, but do 4 door seats have a tray in the middle?
Old Jun 29, 2005 | 10:19 AM
7k rdlne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drive4aliving &raquo;</TD></TR><TR><TD CLASS="quote">I thought so too, my first guess that maybe it was a 4 door seat, but do 4 door seats have a tray in the middle?</TD></TR></TABLE>
nope no tray in the middle on the 4 door seats
Old Jun 29, 2005 | 10:21 AM
yea, mine as the tray in the middle...
Old Jun 29, 2005 | 10:50 AM
7k rdlne's Avatar
wierd, can you post pix of the problem
Old Jun 29, 2005 | 11:54 AM
TunerN00b's Avatar
I thought the 99+ tegs had an additional support under the rear seats, which made the mount points different, something about side impact protection.
Old Jun 29, 2005 | 05:43 PM
Default Re: rear seat differences (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">I thought the 99+ tegs had an additional support under the rear seats, which made the mount points different, something about side impact protection.</TD></TR></TABLE>
interesting...
yea I need to post up some pictures
Old Jun 30, 2005 | 03:35 AM
Dee A Nine's Avatar
Yeah, maybe not all the latches are locked in.
Old Jun 30, 2005 | 04:39 AM
Audi A4's Avatar
Default Re: rear seat differences (Dee A Nine)
the seats are diff man... i think they changed it in 98 not sure but they hook in diff.. so 94-01 is not the same
Old Jul 3, 2005 | 03:39 PM
anyone else have any input?
Old Jul 3, 2005 | 05:02 PM
CleanLikeJdm's Avatar
Hype-R Stalker
If the hole is only off a couple inches, and the one there already is the type it needs.
Why not just make another hole in the correct spot?
Old Jul 3, 2005 | 06:28 PM
Cliffjumper2's Avatar
Default Re: rear seat differences (jaydeemmmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeemmmm &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think you need 94-97 rear seats. They should all fit, except if it's a 4 door. Where the hook is suppose to latch onto might have been damaged due to excessive pushing and pulling of the seats.</TD></TR></TABLE>
nah man, sometimes the seat hook does get damaged, but you're incorrect on this one, like stated by audi a4:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Audi A4 &raquo;</TD></TR><TR><TD CLASS="quote">the seats are diff man... i think they changed it in 98 not sure but they hook in diff.. so 94-01 is not the same</TD></TR></TABLE>
they are different, because the 94-96 (possibly 97) integras didn't have that three piece reinforcement plate (black and heavy) running along the front edge of the rear seat from one side fo the teg to the other.
This was added in 98 to meet a higher standard in crash test regulations or something
but anyway, when they added that extra reinforcement, they had to change the rear seat hook to fit the new piece.
you can just modify the seat hook to help it sit flush, it's basically just a cushion and doesn't effect the integrity of the rear seat if you have it screwed in on the rear mount....or just cut the hook off all together, I've done that a couple times.
Old Jul 4, 2005 | 10:29 PM
Bk2fwd's Avatar
the seating on the 94-96 is thicker... I had the same problem. I traded with someone who had a 96 rear seat. We compared when we swithched.
The 94-96 also comes out a little more than the 97-01.
If you cut the 97-01 seats, they'll just flap around when people sit on them.
Old Jul 4, 2005 | 10:48 PM
NSXtcy21's Avatar
I have never noticed the seats being much different as far as location of mount locations.. i've taken seats from a 95gsr and put them in my 00 with no problem.. but those 95's were in really great shape.. so they might have been newer also.. but they fit find in that dudes 95gsr
Old Jul 5, 2005 | 04:18 PM
Bk2fwd's Avatar
they have different mounting brackets on the front. 97-01 uses 3 iron plates in between the seat and the floor.
RS-2
Apr 26, 2008 12:15 PM
93civicjaydm
Jul 12, 2005 10:22 AM
nimblecivic
Apr 13, 2004 06:23 PM
Grandprix
Jun 29, 2002 10:20 PM
