My Integra shakes at low speeds but not a high speeds.
Old Dec 11, 2007 | 11:05 AM
killacam661's Avatar
Default My Integra shakes at low speeds but not a high speeds.
between 3000 and 4000 my car shakes alot on the drives side. my axels are in securely and are pretty new. what might the problem be?
Old Dec 11, 2007 | 11:10 AM
dc2long's Avatar
Default Re: My Integra shakes at low speeds but not a high speeds. (killacam661)
maybe motor mounts?
Old Dec 11, 2007 | 11:17 AM
dickdragon's Avatar
check your tires. you may have a separated belt.
Old Dec 11, 2007 | 04:10 PM
Default Re: My Integra shakes at low speeds but not a high speeds. (dc2long)
not the mounts, they are realatively new as well. Anyone else
Old Dec 11, 2007 | 05:57 PM
loach-carnage's Avatar
Man I seem to be having the same problem. I think it may be related to the diff but am looking into it further. good luck
Old Dec 11, 2007 | 05:58 PM
SIC_DA9's Avatar
maybe ur alignment is off. or it could be the balance weights on ur rims need to be re done
Old Dec 11, 2007 | 06:01 PM
RichieHemingway's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killacam661 &raquo;</TD></TR><TR><TD CLASS="quote">between 3000 and 4000 my car shakes alot on the drives side. my axels are in securely and are pretty new. what might the problem be?</TD></TR></TABLE>
The problem is you are driving too slow.
Solution?
Haul *** everywhere.
Old Dec 11, 2007 | 06:11 PM
HONDRETTI's Avatar
Default Re: My Integra shakes at low speeds but not a high speeds. (RichieHemingway)
lol
Old Dec 11, 2007 | 06:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RichieHemingway &raquo;</TD></TR><TR><TD CLASS="quote">
Solution?
Haul *** everywhere.</TD></TR></TABLE>
no you timmy im not driving to slow. if i shift at 4200 the rpms dopr to 3000 or so. so go figure. ima take it to the shop tomorrow
Old Dec 11, 2007 | 07:23 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Solution?
lol! i agree with this guy
Old Dec 12, 2007 | 03:38 AM
Dogginator's Avatar
Daisy... Daisy...
Does this happen in all gears at 3000-4000 RPM?
Old Dec 12, 2007 | 06:39 AM
Default Re: My Integra shakes at low speeds but not a high speeds. (Dogginator)
yup in every gear. I dont know why
Old Dec 12, 2007 | 06:53 AM
dohc_profile's Avatar
Solution?
hahhaahahahhaa i was gonna make the same comment.
Old Dec 12, 2007 | 06:58 AM
Winki's Avatar
Your tie rods are probably worn out
Old Dec 12, 2007 | 08:13 AM
tegdude227's Avatar
same thing for me was my axle tho
Old Dec 12, 2007 | 08:24 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killacam661 &raquo;</TD></TR><TR><TD CLASS="quote">yup in every gear. I dont know why</TD></TR></TABLE>
It is something in your engine if the RPM is the key factor.
Old Dec 12, 2007 | 11:10 AM
it cant be my motor, i think my 6 puck clutch tore my axel up with my launches. Its only on the drivers side.
Old Dec 13, 2007 | 12:13 AM
and its not in every gear. Its not in first, during second around2200 rpm the drivers side front of the car shakes like a bitch then stopes after 4000 rpms.....
Old Dec 13, 2007 | 03:42 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killacam661 &raquo;</TD></TR><TR><TD CLASS="quote">and its not in every gear. Its not in first, during second around2200 rpm the drivers side front of the car shakes like a bitch then stopes after 4000 rpms.....</TD></TR></TABLE>
Is it a particular speed range then?
Old Dec 13, 2007 | 04:22 AM
AWD Terror's Avatar
Jack up your car, and see if there's any play in the wheel bearing, tie rods, or ball joints
Old Dec 13, 2007 | 06:14 AM
HONDRETTI's Avatar
Default Re: My Integra shakes at low speeds but not a high speeds. (AWD Terror)
check your lugnuts!!!
Old Dec 13, 2007 | 06:41 AM
jomama's Avatar
Default Re: My Integra shakes at low speeds but not a high speeds. (HONDRETTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDRETTI &raquo;</TD></TR><TR><TD CLASS="quote">check your lugnuts!!! </TD></TR></TABLE>
i would do this, but i don't think it's your problem as it would happen at different RPMs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">Jack up your car, and see if there's any play in the wheel bearing, tie rods, or ball joints</TD></TR></TABLE>
i would start here as it requires little effort. my tie rod end on my driver side is shot to hell and i'm getting vibrations when i turn to the left and now just going straight at different speeds (do you?). (the only thing holding me back from fixing it is the damn cold weather and my procrastination )
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killacam661 &raquo;</TD></TR><TR><TD CLASS="quote">it cant be my motor, i think my 6 puck clutch tore my axel up with my launches. Its only on the drivers side. </TD></TR></TABLE>
did you just answer your own question, then?
Old Dec 16, 2007 | 02:23 PM
Default Re: My Integra shakes at low speeds but not a high speeds. (jomama)
i dunno about at the same speed. i can put it in 5th at 1000 rpms and get up to 5000 but between 2900 and 4000 it shakes. lug nuts are good. tie rods are good. could be a wheel bearing.
Old Dec 16, 2007 | 06:15 PM
EvilPinkEye's Avatar
Default Re: (tegdude227)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegdude227 &raquo;</TD></TR><TR><TD CLASS="quote">same thing for me was my axle tho </TD></TR></TABLE>
I'm betting axles too. When I got my car, it had a bad axle that caused the car to shake like hell. I then changed it, and it improved alot...but the shake is still slightly there....damn autozone remans....
Old Dec 18, 2007 | 02:33 PM
Default Re: (EvilPinkEye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPinkEye &raquo;</TD></TR><TR><TD CLASS="quote">
I'm betting axles too. When I got my car, it had a bad axle that caused the car to shake like hell. I then changed it, and it improved alot...but the shake is still slightly there....damn autozone remans....</TD></TR></TABLE>
damn autozone remans is right. i got one cuz i had it on warranty but me old boot wasnt ripped but with the new one it has improved alot. stil a lil shakey tho. thyanks all. another problem solved.
