Drivers side axle wont pop out.
Old Dec 11, 2007 | 10:58 AM
Deano_D aka
Default Drivers side axle wont pop out.
Ok I am at the last stage of removing my drivers side axle (its hanging freely and out of the hub). I cannot get it to pop out of the half shaft, I have tried tapping it out, and I cannot get a crow bar to grip for prying. Any recommendations?
Old Dec 11, 2007 | 11:28 AM
Deano_D aka
Default Re: Drivers side axle wont pop out. (Deano_D aka "Brick Top")
bump
Old Dec 11, 2007 | 11:40 AM
Deano_D aka
yoo
Old Dec 11, 2007 | 11:54 AM
Syndacate's Avatar
You pulling it as straight as possible?
Old Dec 11, 2007 | 11:59 AM
Deano_D aka
Default Re: Drivers side axle wont pop out. (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">You pulling it as straight as possible?</TD></TR></TABLE>
No, so I need to get the axle completly level?
Old Dec 11, 2007 | 12:02 PM
BryanM.'s Avatar
Resident Gearhead
I had this same issue before and I ended up taking out the intermediate (half-shaft) with axle attached. I put IM shaft in a vice and worked the axle out with a prybar.
Old Dec 11, 2007 | 12:05 PM
Deano_D aka
Default Re: Drivers side axle wont pop out. (mcvtec)
If I unbolt the Int Shaft does it all just slide out?
Old Dec 11, 2007 | 12:23 PM
RYNO48's Avatar
If your at the point you are then its only three more bolts and the **** will be in your lap. But if i were you get the car up higher and get to prybars and put some muscle behind it. Spray some WD-40 in the spline to help slide out.
Old Dec 11, 2007 | 12:26 PM
instrument's Avatar
i usually use a sledge hammer and a mid length extension to tap it out.
Old Dec 11, 2007 | 12:28 PM
lluks_844's Avatar
Default Re: (instrument)
happened to me just pull the half shaft out as well like they said, it will come out alot easier
Old Dec 11, 2007 | 12:31 PM
Intake_Kush's Avatar
Default Re: (lluks_844)
Screw driver and Hammer?
Deano_D aka
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lluks_844 &raquo;</TD></TR><TR><TD CLASS="quote">happened to me just pull the half shaft out as well like they said, it will come out alot easier</TD></TR></TABLE>
Ok I am gonna pull the half shaft then, what size are the bolts and also will I need to drain my tranny fluid now?
Old Dec 11, 2007 | 12:36 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: (Deano_D aka "Brick Top")
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deano_D aka "Brick Top" &raquo;</TD></TR><TR><TD CLASS="quote">
Ok I am gonna pull the half shaft then, what size are the bolts and also will I need to drain my tranny fluid now?</TD></TR></TABLE>
14mm. No, you don't have to drain the tranny fluid. But for piece of mind you could replace the axle seals while the axles are out. It sucks to get everything back together only to find that they are leaking.
Old Dec 11, 2007 | 12:39 PM
Deano_D aka
Default Re: (mcvtec)
ok, thanks man. I am gonna go ahead and replace the seals then. I will pick them up when I get the new axle from the auto parts store.
Old Dec 11, 2007 | 01:16 PM
Deano_D aka
Ok here is what just went down, got the 3 bolts that hold the half shaft off and yanked that hoe right out, tranny fluid came spilling out everywhere out of the gapping hole haha. Grabbed a liquid catcher and cussed a few times, then I held the half shaft in the air with the left hand and smacked the axle with a mini sledge in my right hand 2 hits and the axle broke loose falling to the ground, I yelled out YOUR DONE SON!!! Then laughed at it. Ok I now need to get some tranny fluid, a new axle, and the seals. Got another question though, what is the trick for getting the new axle on?
Old Dec 11, 2007 | 01:28 PM
mastakmk's Avatar
should all go together nicely... i put some wheel bearing grease in there but its not needed. just reverse from removal. i had the same problem in spring. i used the sledge hammer method. worked like a charm.
Old Dec 11, 2007 | 01:29 PM
monicle's Avatar
hehe you didnt think to drain the fluid before pulling the axle?
glad you got it out. yeah the cv is a right hooker to get apart from the half shaft.
Old Dec 11, 2007 | 01:40 PM
Deano_D aka
Default Re: (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">hehe you didnt think to drain the fluid before pulling the axle?
glad you got it out. yeah the cv is a right hooker to get apart from the half shaft.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">
14mm. No, you don't have to drain the tranny fluid. But for piece of mind you could replace the axle seals while the axles are out. It sucks to get everything back together only to find that they are leaking.</TD></TR></TABLE>
Thats why, lesson learned though trial by fire works for me. So the new axle should slip right on to the half shaft? I went ahead and put the half shaft back up and loosely bolted it down so the transmission was not sitting with a gapping hole for a couple days.
Old Dec 11, 2007 | 02:49 PM
1992Si's Avatar
He left out the part about having the car jacked up pretty high on that side. I have done this without having to drain the fluid.
But this will only work on one side at a time.
Be careful when you install the new seal, in fact make sure they gave you the correct seal before you remove the old one. Trust me I've been given the wrong seal more then once.
Use some flat like the flat side of a 2X4 to install the new seal.
appelsos
Jun 27, 2011 07:29 PM
Hoppa
Dec 5, 2006 08:51 AM
huepowered
Mar 27, 2006 12:33 PM
ActiveAero
Jul 4, 2005 05:38 PM
dacosta
May 29, 2005 06:51 PM
