OIL Leak !!!!???
Old Dec 11, 2007 | 09:54 AM
F22dreams's Avatar
Default OIL Leak !!!!???
I have a 95 accord EX 2.2. i seem to run into this problem again with the oil leak rite on the side of the alternator belt bottom pully is there any way around fixing up the balaence shaft/cam shaft seals and is there any other way to prevent this or should i say prolong it for some time at least ...
Old Dec 11, 2007 | 10:11 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: OIL Leak !!!!??? (F22dreams)
So you are saying you have located the leak and it is coming from the front balance shaft seal or the camshaft seal? Both?
On the front balance shaft seal, do you have the retainer installed?
When were those seals last replaced? When last replaced, did the shaft or housing get scratched at all?
Old Dec 11, 2007 | 10:40 AM
F22dreams's Avatar
Default Re: OIL Leak !!!!??? (TouringAccord)
every thing was replaced 6 months ago sum time and every thing was new with no problems at all i just needed a top gasket for a very minor leak.. i'am just out done is there any way to see if this is really the problem i just removed the bottom the covers the engine the leak is rite next to the oil pan dam
Old Dec 11, 2007 | 10:46 AM
H-T Order of Merit
I don't know if it's just me but that is hard to read and understand.
What is the top gasket? Valve cover gasket?
Are you able to take a picture of the leak and post it?
Old Dec 11, 2007 | 10:58 AM
F22dreams's Avatar
sorry about dat i'am working on it now
Old Dec 11, 2007 | 11:10 AM
F22dreams's Avatar
well i pretty sure the seals are problem. i was suppose to be 2 work an hour ago so, i'll put pics up later to show the world what da hell went wrong but thanks 4 ya help once again
Old Dec 11, 2007 | 12:01 PM
F22dreams's Avatar
Oil leak: Sudden oil loss and resultant severe engine damage could be the result of front balance shaft oil plug popping out. (1994-96)
http://consumerguideauto.howst...2.htm
Old Dec 11, 2007 | 12:19 PM
Honda-Master's Avatar
after replacing the seals ,, make sure to install the balance shaft seal retainer ..
Old Dec 11, 2007 | 01:02 PM
Twixle's Avatar
ate my pixel
Default Re: OIL Leak !!!!??? (Honda-Master)
new belts and seals buddy
Old Dec 12, 2007 | 03:59 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F22dreams &raquo;</TD></TR><TR><TD CLASS="quote">Oil leak: Sudden oil loss and resultant severe engine damage could be the result of front balance shaft oil plug popping out. (1994-96)
http://consumerguideauto.howst...2.htm</TD></TR></TABLE>
yeah... thats why I asked about the balncer shaft seal retainer.
mrau92me
Jul 17, 2018 07:00 AM
Allout
Feb 16, 2010 03:56 PM
rulvis
Dec 21, 2008 06:29 PM
GaRn
Feb 6, 2006 08:33 AM
Chiovnidca
Jan 3, 2003 10:28 AM
