Oil Leak... What could it be?
Old Dec 11, 2007 | 04:12 AM
inneyeseakay's Avatar
Default Oil Leak... What could it be?
I have an oil leak comeing from the right side (distrubuter side) of my B18c1. I am looking for possible causes. It appears to be coming form in front of the distributer around the VTEC silonoild and the black plug in the side of the valve cover... anyone have any ideas on possible gaskets or other problems that may be causing the leak?
This area:
Old Dec 11, 2007 | 04:44 AM
PrinceAli132's Avatar
Default Re: Oil Leak... What could it be? (inneyeseakay)
Part # 12
http://www.sonsacuraparts.com/...dIrno=
Vtec solenoid gasket
Ali
AWD Terror's Avatar
There is multiple things it could be. You will have to clean your engine, and see where the leak starts.
Could be something as little as the valve cover, or it could be something as serious as the main seal behind the flywheel.
Old Dec 11, 2007 | 05:00 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Oil Leak... What could it be? (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Part # 12
Could be part #8 as well.
Old Dec 11, 2007 | 05:10 AM
Default Re: Oil Leak... What could it be? (PatrickGSR94)
Can't tell to well from the pic and the description said seal. But is that the cam seal?
Ali
Old Dec 11, 2007 | 05:24 AM
polishedturd's Avatar
I like PIE
cam seal is most likely leaking. happens all the time with the p.o.s. oem ones . just pick up a metal one from "password" for like $18 i think.
heres the site where i got mine http://www.streetrays.com
ps: its very simple to replace......takes about 15 min.
Old Dec 11, 2007 | 05:25 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Oil Leak... What could it be? (polishedturd)
+3 for cam seal, more common than a vtec solenoid gasket (although that could be the case as well)
Old Dec 11, 2007 | 05:26 AM
mr_gs-r's Avatar
sounds like a leaky cam seal, replace it with a metal dual or tripple o ring version. Alot of companies offer them like pw jdm and skunk2.
Old Dec 11, 2007 | 06:32 AM
berb_15's Avatar
Default Re: Oil Leak... What could it be? (mr_gs-r)
while you have the top end partially apart it probably wouldnt hurt to just replace all the seals around the cams/solenoid/valve cover area, once one starts the others are likely to follow
Old Dec 11, 2007 | 08:59 AM
Community Builder
Honda re-designed those cam plug seals about mid-way through the 3rd gen Integra's life. The old design was rubber, which I had on my 94. I replaced it back in January 2003 with the OEM redesigned version, which is plastic with o-rings on it. Now probably 130,000 miles later it still works just fine.
Metal ones are for showy bling-blang, which is cool if that's what you like. The OEM redesigned version is only like 5 bucks and has that OEM quality and understated-ness, which is what I prefer.
Old Dec 11, 2007 | 11:53 AM
lmike6453's Avatar
could be ditributor o-ring....that's what is leaking from my teg right now, but very light leakage.....if you take off your valve cover DO NOT FORGET TO REPLACE THOSE GASKETS.....me and many other people i know have had multiple problems w/ vlave cover gaskets slowly leaking
Old Dec 11, 2007 | 12:43 PM
Default Re: (lmike6453)
I guess I will start by replacing the VTEC Solonoid Gasket, Cam Seal, and ValveCover Gasket and see if that fixes it
Can I get the redesigned OEM cam seal from a Honda Parts Dept? or do I have to order it?
If it doesn't stop I'll try the distributer o-ring, but this is some pretty heavy leakage. It's leaking about a qt in a week.
Old Dec 11, 2007 | 12:46 PM
A big thanks to everyone that helped so far!
Old Dec 11, 2007 | 12:52 PM
Fern413's Avatar
Default Re: (inneyeseakay)
cam seal
Old Jan 22, 2008 | 03:59 PM
DB8-TUNER's Avatar
Ok, I have the same problem. I replaced the VTEC solenoid gasket, Cam plug, and the Distributor O-ring but still leaks!! I'm really starting to think its the head gasket, but it still looks like it leaks from the VTEC solenoid area.
Old Jan 22, 2008 | 05:18 PM
racebum's Avatar
Default Re: (Fern413)
part 8 and 12, the vtec seal comes with a new screen and the cam plug is known to leak. I just bought both after having the exact same problem. Installed both in roughly 10 minutes. Pull the 3 bolts that hold the vtec, pull the seal, pop in the new one, use a flat blade screwdriver and pop out the cam seal, pop in the new one after wiping everything off and you're good to go. Anyone know the ft/lb you are supose to use on the vtec? i just went "fairly tight" with a 12" 3/8" ratchet. Also, MR Db8, you might have a little spec of crud in one of the seals. It doesn't take much to cause a leak. Pressure wash your engine, then drive it for 30-50 miles so you can see exactly where the oil is coming from and post a pic & thread. I'm sure we can figure it out.
Old Jan 25, 2008 | 11:12 PM
jdmjunkie8's Avatar
looks like the cam seal to me.
Old Jan 25, 2008 | 11:37 PM
x1aO's Avatar
most likely is your vtec solenoid.
Old Jan 26, 2008 | 08:24 AM
racebum's Avatar
Default Re: Oil Leak... What could it be? (x1aO)
$24 buys both at the dealer, why bother, just replace both.
ozamo003
Jan 30, 2015 02:53 PM
NJ-JDM
Oct 23, 2013 02:54 PM
jdmNit
Apr 1, 2010 08:47 PM
jakop92
Nov 15, 2009 11:33 AM
em1gangsta
Jan 1, 2008 09:42 PM
