Does cam gear adjustment affect timing belt tension?
Old Jun 26, 2002 | 09:16 PM
EK4 hatchback's Avatar
Default Does cam gear adjustment affect timing belt tension?
Just as the topic said, thanks.
Old Jun 26, 2002 | 09:28 PM
Reid's Avatar
Global Moderator
Default Re: Does cam gear adjustment affect timing belt tension? (EK4 hatchback)
No.
Old Jun 26, 2002 | 09:51 PM
Default Re: Does cam gear adjustment affect timing belt tension? (Reid)
Good.....thanks.
Old Jun 26, 2002 | 10:10 PM
EGtoR's Avatar
But I heard some tuner said that you should loosen the timing belt when you adjust the cam gears.
Old Jun 27, 2002 | 02:47 AM
PYITR821's Avatar
Default Re: Does cam gear adjustment affect timing belt tension? (EGtoR)
Nope.
Old Jul 2, 2002 | 02:35 AM
MikeSarr_GSR's Avatar
Default Re: Does cam gear adjustment affect timing belt tension? (JUNtypeR)
nope, just loosen the fasteners and rotate the cam with a 14mm
re tq the fasteners and you are off to the races
Old Jul 2, 2002 | 03:49 AM
Turtle's Avatar
Default Re: Does cam gear adjustment affect timing belt tension? (MikeSarr_GSR)
Sine they have to be the same diameter as stock, nothing should change about the belt at all...nothing.
Old Jul 2, 2002 | 04:20 AM
kenji's Avatar
25 Year Member
Default Re: Does cam gear adjustment affect timing belt tension? (401-2001)
Look at it this way:
There are two main parts to an adjustable cam gear, right? The inner and outer. The timing belt is in contact with and rides on the outer part. The inner part is attached to the cam.
When you adjust the cam timing you are moving the cam and the outer part of the cam gear is stationary. With this being said, the timing belt tension will not be affected.
-kenji
Old Jul 2, 2002 | 04:23 AM
Willard's Avatar
Only if the cam is bent.
Old Jul 2, 2002 | 10:13 PM
Default Re: Does cam gear adjustment affect timing belt tension? (Willard)
or you are doing it incorrectly, I had an issue with this until
I learned the proper way... ugh
Old May 31, 2004 | 07:09 PM
slipstreamsi's Avatar
so if you replace your cam gears, how do you the belt back onto the gears? seams to tight to pull back on. any sugestions on that?
Old May 31, 2004 | 07:16 PM
ZygSpeed's Avatar
Default Re: Does cam gear adjustment affect timing belt tension? (slipstreamsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slipstreamsi &raquo;</TD></TR><TR><TD CLASS="quote">so if you replace your cam gears, ... any sugestions on that?</TD></TR></TABLE>
Yes, when replacing the cam gears you'll need to loosen the timing belt!
Old May 31, 2004 | 07:18 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slipstreamsi &raquo;</TD></TR><TR><TD CLASS="quote">so if you replace your cam gears, how do you the belt back onto the gears? seams to tight to pull back on. any sugestions on that?</TD></TR></TABLE>
You have to loosen the tensioner before removing and installing the sprockets, then re-tension the belt.
Old May 31, 2004 | 07:22 PM
Default Re: Does cam gear adjustment affect timing belt tension? (Padawan)
thanks!
Old May 31, 2004 | 08:45 PM
TodaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;Do es cam gear adjustment affect timing belt tension?&lt;HR&gt;&lt;/BLOCKQUOTE&gt;Only if the cam is bent. &lt;IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emsmilep.gif" BORDER="0"&gt;</TD></TR></TABLE>
Or if you are trying to adjust stock cam gears lol
scoob8000
Dec 19, 2011 11:57 AM
SCHYBRID
Apr 5, 2006 05:33 PM
4DRmafia
Dec 22, 2005 08:45 PM
slipstreamsi
May 31, 2004 05:53 PM
Lightning Lover.
Nov 30, 2003 06:46 PM
