Took out my cluster to change the bulbs, now..
Old Dec 10, 2007 | 09:15 PM
slow_cx's Avatar
Default Took out my cluster to change the bulbs, now..
My blinkers don't work.. Wtf? Can anyone help me out?
Old Dec 10, 2007 | 09:16 PM
93egSLEEPER's Avatar
Default Re: Took out my cluster to change the bulbs, now.. (slow_cx)
sounds like you forgot to hook something back up, or you hooked something up backwards. does everything else work??
Syndacate's Avatar
I've taken out MANY civic clusters and never ran into the problem of the directional lights not working.
Is it just the lights on the dash - or they're not working at all?
Did you damage the harness unplugging the cluster?
Old Dec 10, 2007 | 09:22 PM
92slowcivic's Avatar
Default Re: Took out my cluster to change the bulbs, now.. (Syndacate)
you probably forgot to plug your hazard lights back in. i would put money on it.
Old Dec 10, 2007 | 09:24 PM
slow_cx's Avatar
No damage was done. It was very simple to do.. But i get no action whatsoever.. Not from the indicators or the blinker themselves
lowfast's Avatar
Recheck your connections.
Old Dec 10, 2007 | 09:28 PM
Default Re: (lowfast)
did you check to see if you plugged your hazard lights in????
Old Dec 10, 2007 | 09:30 PM
SOHCejcivic's Avatar
Default Re: (92slowcivic)
i'll third the guess of unplugged hazard switch.
Old Dec 10, 2007 | 09:31 PM
slow_cx's Avatar
Ha! No.. i just checked and it was not all the way in. That was it. Thanks for the help!!
Old Dec 10, 2007 | 09:32 PM
Default Re: (SOHCejcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic &raquo;</TD></TR><TR><TD CLASS="quote">i'll third the guess of unplugged hazard switch.</TD></TR></TABLE>
thank you. it is such an easy mistake to make and it is the only logical explanation for this problem. it would be virtually impossible to break your turn signals by taking out your cluster.
happy to help.
Old Dec 10, 2007 | 09:38 PM
Syndacate's Avatar
Ah, I forgot that the '92-'95 shared the bezel that the hazard switch was in with the cluster was in.
Don't have that problem with a 6th gen .
Old Dec 10, 2007 | 09:40 PM
slow_cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92slowcivic &raquo;</TD></TR><TR><TD CLASS="quote">
thank you. it is such an easy mistake to make and it is the only logical explanation for this problem. it would be virtually impossible to break your turn signals by taking out your cluster.</TD></TR></TABLE>
Yea, thats why i was so confused as to what i could have possibly done. I knew i had plugged it in so i ruled it out at the beginning. next time i'll be double sure i have it in ALL the way. Thanks again!
Old Dec 10, 2007 | 09:55 PM
Default Re: (slow_cx)
you know how i came across this information? i've done it. probably everyone who has taken their dash apart has. it's soooo easy to forget to plug that back in. simple mistake, simple fix.
Old Dec 10, 2007 | 10:08 PM
i learned from that one too. i got sooooo mad because it didn't work, so when i started to take it all apart again i noticed it wasn't plugged in. snapped her in and boom-bam....signals!
NataSS Inc
Oct 16, 2012 07:52 PM
dadrought6
Nov 28, 2010 04:10 PM
dth0ng69
11
Jun 8, 2008 05:40 PM
SPOOLINmatt
Mar 31, 2008 09:51 PM
bushfreakz
Aug 24, 2003 06:10 PM
