bad idle concern
Old Dec 10, 2007 | 05:45 PM
jdm_racer831's Avatar
Default bad idle concern
i have a 92 civic si 1.6 vtec and the car has a bad idle up down up down. no check engine light, recently i replaced the thermostat and changed the IAC valve but i got the part at a junk yard. And the concern is still there. Is there anything elso i should check?? i need to pass smog!!!! HELP ME
Old Dec 10, 2007 | 05:50 PM
b18c1ej8's Avatar
Default Re: bad idle concern (jdm_racer831)
clean the iacv if you haven't , check for vacum leaks, and check your tps, or sometimes even a layer of carbon can build up on the throttle body and get stuck a little open
Old Dec 10, 2007 | 05:54 PM
i already cleand the Iac i just got some carb cleaner and cleand it out. but now that you mention my throttle body i used this chemtool 3 step fuel system cleaner and i remember that one of the steps was to spray some **** in the manifold maybe something got stuck in there?? you think that might be the problem?? HMMM
Old Dec 11, 2007 | 05:51 AM
z6hatchboy's Avatar
Clean the fast idle thermo valve (fitv), under the throttle body
Old Dec 22, 2007 | 08:03 AM
Integra_drk's Avatar
have you gone thru the idle adj procedure...warm car up turn off disconect the iac valve start up adj to 600-700 with adj screw turn off reconect iac and restart
edmfactory
Jan 13, 2014 06:54 PM
sullins
Jul 11, 2011 03:36 PM
jdmCivic925
Oct 25, 2005 02:37 PM
caLiH22A
Aug 24, 2004 08:05 PM
FourthGenHatch
Apr 29, 2002 11:08 AM
