Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Symptoms of Bas Wheel Bearings?
Old Jun 26, 2002 | 08:22 PM
Suprdave's Avatar
Default Symptoms of Bas Wheel Bearings?
I think I might have Bad Front Wheels Bearings...can anyone list off the symptoms?
Thanks...
Suprdave
Old Jun 26, 2002 | 08:25 PM
Chris's Avatar
Default Re: Symptoms of Bas Wheel Bearings? (Suprdave)
excessive play.. "dartiness" on the track.
Hold wheel at 9 and 3 o'clock.. rock back and forth..
Old Jun 26, 2002 | 08:32 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Symptoms of Bas Wheel Bearings? (Chris)
Hold wheel at 12 and 6 and rock up & down while off the ground.
Sometimes it's just plain hard to tell. When you corner left, if you hear a wobbling noise from the right, there's a good chance the right front bearing is shot.
Warren
Old Jun 26, 2002 | 08:48 PM
johng's Avatar
I'll show you mine. That'll learn ya. When you grab the hub with your hands and try to move it, it'll rock in/out and make "clunk" sounds.
Old Jun 26, 2002 | 10:46 PM
Suprdave's Avatar
Default Re: Symptoms of Bas Wheel Bearings? (johng)
I'll tell you guys my symptoms:
Makes a 'clunking' noise while driving.
Noise gains repetition with speed.
Noise goes away while cornering and while accelerating hard.
Basically It only clunks when the wheel is perfectly straight. Sounds like its coming from the right\front. Thanks in Advance.
Suprdave
Old Jun 27, 2002 | 03:54 AM
SJR's Avatar
SJR
sounds like it could be a CV joint, actually.
Old Jun 27, 2002 | 04:48 AM
John's Avatar
New User
Default Re: Symptoms of Bas Wheel Bearings? (SJR)
What about a loud drone sound while cruising on the highway? Or is that a sympton of a bad hub?
Old Jun 27, 2002 | 05:18 AM
SJR's Avatar
SJR
Default Re: Symptoms of Bas Wheel Bearings? (DunReit)
if the drone has some kind of periodicity (waa-waa-waa) that varies with speed, chances are it is a bearing.
Old Jun 27, 2002 | 05:41 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Actually, a CV joint going bad would only make noise when accellerating and turning. (or both at the same time).
Sounds like the bearings. Most hondas I have worked on have sealed bearing/hub assemblys. Easy enough to take off, if you have the right tools. My recommendation would be to source the parts from a shop and not Honda/Acura.
Old Jun 27, 2002 | 06:06 AM
Suprdave's Avatar
Default Re: Symptoms of Bas Wheel Bearings? (madhatter)
Thanks Guys, I think it's the Wheel Bearings then...
I'm gonna get the car up on stands and check the 'wobble' today.
Suprdave
Old Jun 27, 2002 | 06:51 AM
SJR's Avatar
SJR
oops. You're right. And you forgot that a CV may also clunk when braking... I just never had a bearing actually clunk on me, they always seemed to go "waa-waa"...
Ah, I love them highly technical terms, linke clunkin', waa-waa, etc.
Old Jun 27, 2002 | 07:55 AM
allenp's Avatar
It's funny, because in the NVH engineering field, those words are highly regarded, widely known technical terms. In the clutch/driveline business that I am in, "clunk," "squeal," "eek," "squeak," and "moan" are all rigidly defined terms!
Old Jun 27, 2002 | 07:58 AM
Suprdave's Avatar
I guess it is more like a waaa-waaa-waaa at speed...
Sorta like the sound as if there was a flat spot on the tire and it hit it the faster you went and the sound slowed down when I slowed down.
Going out to check it now.
Suprdave
How safe is it to keep driving on these? Till I get some parts in.
[Modified by Suprdave, 10:59 AM 6/27/2002]
avio
Apr 11, 2010 12:40 PM
Blastek
Oct 18, 2004 08:34 AM
sf89lx
Aug 26, 2004 10:05 AM
Muckman
Sep 30, 2003 06:52 AM
2SLO
Nov 6, 2002 08:21 AM
