My new whip
Old Dec 10, 2007 | 04:36 PM
FSS13foxtrot's Avatar
Default motor problems with b16 da
got a DA integra LS today, has a b16A , smokes black out of the exhaust, what is black smoke caused from? im replacing the head gasket regardless, along with other gaskets, also vtec doesnt kick in , it was rewired but i think they didnt do it right, i just got back and havent taken time to look or adress these issues, lmk what u guys think, im going out to take a look/ clean interior, pics up soon, also idles weird, sometimes gotta gas it or it will die, i am new to B series, as i have always had a D, but like dirty rice says, its time to put the d series in the bed .....lol ok enough of me. LMK what u think.
Also forgot to add it has an ls tranny
Modified by FSS13foxtrot at 7:34 PM 12/10/2007
Modified by FSS13foxtrot at 5:53 PM 12/19/2007
Old Dec 10, 2007 | 04:39 PM
posHonda's Avatar
how much did you get it for?
Old Dec 10, 2007 | 05:07 PM
Default Re: (posHonda)
traded a stock crx for it
Old Dec 10, 2007 | 05:18 PM
MR2Quick99's Avatar
Default Re: (FSS13foxtrot)
Black smoke, mixture is rich. If its more on the blue side then its definitely oil in the cylinder(s)
Old Dec 10, 2007 | 06:27 PM
Default Re: (MR2Quick99)
thanks for responses , heres some pics
Gutted it right away the comes cleaning it up
Old Dec 10, 2007 | 08:09 PM
Arsenal's Avatar
Black = Fuel
Blue = Oil
White = Coolant.
Old Dec 10, 2007 | 10:09 PM
Default Re: (Arsenal)
can u emphasise on what it can be fuel wise? main area to check got a new fuel filter
Old Dec 10, 2007 | 10:33 PM
krytoi's Avatar
i think that dumbass left u with ls ecu and u getting to much fuel and air and no vtec
Old Dec 11, 2007 | 12:22 AM
Default Re: (krytoi)
its a pr3, i was thinking the same thing, i put in my ecu and it does the same thing, it fixed some things because his ecu sucked ***** but mine throws the code for a map sensor and a mechanical issue, it runs funny, either way im gonna change all the gaskets and take a look inside obviously to see what else possibly wrong there is, and obviously attend the issues given by the ecu codes, either way its a swap and seats etc....i can sell them for the value of my crx along with the other minor crap thats in the car, i dunno ill keep you all posted with pics etc of everything, thanks for all of the input, i gotta trade these seats tho......i hate them......
Old Dec 11, 2007 | 12:26 AM
is it just me or is this hooked up worng? i know theres no concept of using proper tube legths/ non ghetto tubes look at the intake mani. lmk what u all think, also more pics up tomorrow of the v tec solenoid wiring that was done(i wonder how/why people let their cars run with this kind of rigging....)
Old Dec 11, 2007 | 05:36 AM
Arsenal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FSS13foxtrot &raquo;</TD></TR><TR><TD CLASS="quote">can u emphasise on what it can be fuel wise? main area to check got a new fuel filter
Running rich. The car could be in limp mode, which would most likely be an o2 sensor. Or, if it has an adjustable regulator, it might be set to high. Or larger injectors with a larger fuel pump.
Old Dec 11, 2007 | 06:28 AM
berb_15's Avatar
I wouldnt start parting the car out quite yet I like it minus the seats like you said.. but it looks like it has potential just needs a little tlc. I'd get a manual or some other wiring diagram and trace those wires and get the proper ecu if you didn't already... if it still doesnt run right you might be able to take it to a tuner even though you shouldnt have to... fix all the sensors that are throwing codes, i've have unplugged sensors cause the car to run rich, goodluck keep us updated
Old Dec 11, 2007 | 11:16 PM
Default Re: (berb_15)
new pics up in 5 mins.!!
Old Dec 11, 2007 | 11:35 PM
Another inside pic...just cuz
Intake manifold, tomorrow i am getting the proper hose lenths and fittings, not the ghetto crap that was on it or still is on it.
Whole engine bay pic, this will be cleaned soon as soon as i have time
I repaired my sunroof as well... had to take the head borad off, but i replaced it , no sweat.
Before(taken out of course, no glass....
after, installed properly, work like a champ
Modified by FSS13foxtrot at 12:57 AM 12/12/2007
Old Dec 11, 2007 | 11:59 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
If your car is running rich...and you plug in an ECU and it says "map sensor fault"....maybe it's a map sensor fault? Are the MAP and TPS plugs switched? Are the CTS and VTEC solenoid plugs switched?
Why are you replacing all the gaskets? Are they leaking? Dont fix what isn't broken...you might end up breaking something in the process. This theory goes especially for the head gasket. Why change that if it's perfectly good? There's no head gasket interval....just wait till it blows...if it ever blows.
Fix what's wrong with it first man. THEN go for the other auxillary stuff. Try taking it somewhere to have it diagnosed. It may pay off in the end. You dont have to deal with a headache..and you're not blindly throwing parts at it.
BTW, you have a vacuum leak....unless you plugged the GIANT barb coming off your intake manifold. Check the pics. You'll see it. It's on the front of the manifold pointing at the FPR.
Old Dec 12, 2007 | 12:42 AM
Default Re: (B serious)
im just replacing what obviously needs to be fixed, if i see something else that may soon need to be maintained i just do it then and there as well, i did take that hose off, i couldnt stand it, just looking at it.
Old Dec 12, 2007 | 12:43 AM
VRD^sam's Avatar
damn that thing is slammmed
Old Dec 12, 2007 | 01:13 AM
Default Re: (VRD^sam)
only way to do it
Old Dec 12, 2007 | 10:03 AM
ef9vlad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRD^sam &raquo;</TD></TR><TR><TD CLASS="quote">damn that thing is slammmed</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FSS13foxtrot &raquo;</TD></TR><TR><TD CLASS="quote">only way to do it </TD></TR></TABLE>hell yeeah!
Old Dec 12, 2007 | 02:50 PM
dickdragon's Avatar
white steelies ftw!
Old Dec 12, 2007 | 02:53 PM
inostageh23's Avatar
black smoke is an indicator that your running rich, check your sensors.
Old Dec 12, 2007 | 03:16 PM
Arsenal's Avatar
Default Re: (inostageh23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inostageh23 &raquo;</TD></TR><TR><TD CLASS="quote">black smoke is an indicator that your running rich, check your sensors.</TD></TR></TABLE>
No ****! its only been stated a million times!
Old Dec 12, 2007 | 03:17 PM
i will replace my sensors as soon as im not sick i woke up this morning hella sick and i believe its bc i need a damn heater in my garage,its freezing, o well, tomorrow ill get all this done and take pics/show work i have done. tomorrow night is also beer pong! as you can see the table in the backround in some of the pics...
Modified by FSS13foxtrot at 5:20 PM 12/12/2007
Old Dec 12, 2007 | 04:29 PM
ef9vlad's Avatar
honda-tech beer pong nit only hondas allowed
Old Dec 12, 2007 | 04:41 PM
tegG2's Avatar
Default Re: My new whip (FSS13foxtrot)
Nice trade man. MY first intagra was a 92 LS white with blue interior. With the interior cleaned up nice that blue looks really awesome. I got alot of comments on it, I wanted black at the time but it really grew on me. Ill post some pics b/c I miss her and for DA's!
Fart can came with it, not my doing. haha
