spark plug #2 full of oil!
i just pulled my spark plug wires and number 2 is FULL of oil.. i looked at the gasket and its almost new... idk if the O ring is just not sealing.... wouldnt this make number 2 cylinder run like **** or not even work???
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jbur074 »</TD></TR><TR><TD CLASS="quote">k cool.. but do i need a new spark plug for that spot?? is it making it not fire right nowor just burning oil</TD></TR></TABLE>
Buy one anyways.
****, buy 4, they're 4 bucks a piece.
EDIT:
Jeez, you're f88king cheaper than me.
Modified by Syndacate at 1:19 AM 12/11/2007
Buy one anyways.
EDIT:
it's the upper plug seal. places usually sell them in kits, but you might be able to snag just one. that'd be the ONLY reason why it's filling with oil. even if it looks okay, it's obviously not sealing.
clean it out, clean the plug and clean out the plug wire. it's not firing because it's submerged in oil....causing the misfire.
they are called valve cover gromettes you should replace them they will fix your problem make sure you get a bottle of honda bonda also use it on the edges of the valve cover it will help the cover seal on the corners ( with a new gasket of course)
VTEC_Du_Ma_Mai
Sep 5, 2008 01:41 PM
gixxer6
Oct 29, 2002 01:10 PM
