is my ignition switch bad?
i tested my ignition switch by using the chart and a meter and continuity was good between every one except the last which was the two blue/white wires with the key out. i got no continuity between those two except when i put my key in? Then it would just have continuity when i wiggled it around? does this mean new switch time? or could it just be the cylinder? thanks for the help!
chito_zan
Aug 10, 2004 05:27 PM
