95 honda accord problem!!! plzz help
Old Dec 10, 2007 | 01:54 PM
wesk18's Avatar
Default 95 honda accord BRAKE LAMP PROBLEM!!!!!!SOLVED
BRAKE LAMP SOLVE, if u tried everything and still no luck, then it might be the lil box on the left side inside where the bulbs go, its not getting ground one of the pins!
Old Dec 10, 2007 | 02:31 PM
TheMuffinMan's Avatar
He knows where you live!
brake fluid.......
Old Dec 19, 2007 | 05:47 PM
wesk18's Avatar
Default Re: (TheMuffinMan)
i did put brake fluid too
Old Dec 19, 2007 | 05:54 PM
IMALLSLO's Avatar
Default Re: (wesk18)
If all the bulbs are good,you could have a bad brake light sensor. The sensor is attached to the rear on the brake lamp housing. A little hard to diagnose though. I believe the sensor thinks a bulb is bad thus illuminating the light. Just to confirm....the light under the trunk area on your dash?
Old Dec 30, 2007 | 04:32 PM
wesk18's Avatar
Default Re: (IMALLSLO)
yes the light that says brake lamp under the trunk light when it lights up when your trunk is open...
so i should check for what??
the sensor your talking about, is it a small box??
well i have two of those if is that, one is new and the other one is the stock one i have the new one on,
well this problem only happens when i step the brake pedal it use to do it just as soon as i turn the car on but like now i installed two new wiring sets for the left and right now it does that problem
i am wondering whats is a blue wire that looks like the one attach to the left wiring set
do u know?
Old Dec 30, 2007 | 05:44 PM
91h22cb7lx's Avatar
could also be a bad level sensor in the master, its built into the cap, the two wires coming out, and try and move the parking brake lever up and down, maybe its out of alignment and thinking you still have it up
Old Dec 30, 2007 | 06:02 PM
IMALLSLO's Avatar
Default Re: (91h22cb7lx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91h22cb7lx &raquo;</TD></TR><TR><TD CLASS="quote">could also be a bad level sensor in the master, its built into the cap, the two wires coming out, and try and move the parking brake lever up and down, maybe its out of alignment and thinking you still have it up</TD></TR></TABLE>
Wrong light. Not the "brake" light. Its the light that lights up like a door is open,instead it shows in the trunk area. Its the little white boxes on the housing of the light. Id double check all the lights. Just because they dont look burned up,doesnt mean it has a bad connection.
Old Dec 30, 2007 | 06:03 PM
91h22cb7lx's Avatar
oh the brake bulb light my bad
Old Dec 31, 2007 | 07:39 PM
wesk18's Avatar
do u think it could be the brake switch under the steering wheel where the brake pedal is??
Old Dec 31, 2007 | 07:45 PM
wesk18's Avatar
its ground
88accord
Mar 24, 2018 09:29 PM
markm1993
Mar 10, 2017 01:35 PM
richkuan
Jun 10, 2015 07:20 AM
mnwildfan2k
Jan 1, 2014 07:53 AM
Idontknowanything
Oct 11, 2004 03:52 PM
