Please help.. Gauge cluster completely out.. PLEASE!!!!
Old Dec 10, 2007 | 09:09 AM
soon2be1's Avatar
Default Please help.. Gauge cluster completely out.. PLEASE!!!!
Ok the speedo cluster is out.. no tach, no speedo, no fuel and water temp. When i start the car the Batt and SRS lights come on.. Then nothing.. I dont have turn signals at all.. Not sure if it matters but the clock on the dash doesnt work either. When i put the hazards on they light up on the dash. Same with the brights.. But other then that nothing.. Please help i need to register the car soon..
Also its a 92 si the idiot i bought the car from said he was messing with the stereo.. which is a pioneer unit.. And the stuff went out.. He isbnt being helpful either...
Once again thank you,
Brandon
Old Dec 10, 2007 | 09:36 AM
lowfast's Avatar
Check the fuses?
Old Dec 10, 2007 | 09:38 AM
soon2be1's Avatar
Default Re: (lowfast)
Yeah.. The fuses and the relays... replaced them all..
Old Dec 10, 2007 | 10:41 AM
soon2be1's Avatar
Default Re: (soon2be1)
Does anyone have an idea??? PLEASE HELP!!!!
Old Dec 10, 2007 | 11:49 AM
BlueIntegraBoy's Avatar
Sounds like the backup fuse popped, found in the engine bay
Old Dec 10, 2007 | 11:57 AM
soon2be1's Avatar
Default Re: (BlueIntegraBoy)
Please where is this back up fuse??
call me if you can i am about to blow this damn car up... LOL!!!
228-596-3614
Brandon
Old Dec 10, 2007 | 12:04 PM
In the engine bay fuse box
Old Dec 10, 2007 | 12:54 PM
soon2be1's Avatar
LOL yeah i replaced and checked them... When i checked them the back up was dlown but i replaced it and it hasnt blown since but nothing works still.. Now i just talked to the idiot that put the stereo in and he did a cob job on it!! Anyone know what is tied into the two? Stereo and cluster? Thank you for your help with this!!!
Old Dec 10, 2007 | 01:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2be1 &raquo;</TD></TR><TR><TD CLASS="quote">LOL yeah i replaced and checked them... When i checked them the back up was dlown but i replaced it and it hasnt blown since but nothing works still.. Now i just talked to the idiot that put the stereo in and he did a cob job on it!! Anyone know what is tied into the two? Stereo and cluster? Thank you for your help with this!!!</TD></TR></TABLE>
The harnesses run parallel, but I can't remember if they are on the same harness or two harnesses.
Old Dec 10, 2007 | 05:21 PM
ca-rs's Avatar
Same harness as cluster. Just go through the wires as obviously he screwed up somewheres.
Old Dec 10, 2007 | 05:35 PM
4dohs4mohoes's Avatar
Default Re: (ca-rs)
Sounds like a short somewhere. I've seen this alot. On most Hondas the radio harness and cluster harness are tied together. Does your radio fuse blow at all? Ever? And do your tail lights work?
Old Dec 11, 2007 | 01:09 PM
soon2be1's Avatar
Default Re: (4dohs4mohoes)
No heres the funny thing.. looking at the scamatics from shopkey.. a red/black wire is the only one that goes to both of them.. now.. he didnt hack the factory harness but when he put the adapter in he left a couple of hot wires exposed and contacting ground.. Now the idiot also cut the 8 guage amp power cable and wrapped the power for the head unit around that!!! oh yeah and didnt even tape it off or tell me about it.. So i dont have a clue were to go from here..
B_Swapped93
Jul 18, 2013 03:56 AM
si92prelude
Nov 4, 2010 06:32 AM
turbogrs
Aug 31, 2010 10:36 PM
superfast666
Apr 11, 2008 12:27 PM
hypnotize
Sep 2, 2004 01:45 PM
