valve adjustment on b18b
Old Dec 9, 2007 | 09:44 PM
bara6075's Avatar
Default valve adjustment on b18b
I was trying to do the valve adjustment on my b18b but the lock nuts seem to not tighten or loosen. am i doing something wrong here cuz i put a flathead on top of it.... or is there a special tool that i have to get to tighten or loosen i was using a regular metric wrench.
Old Dec 9, 2007 | 09:49 PM
.xcalibur.'s Avatar
are you using a 10 or 12mm to loosen the nuts first? then using a flathead to do the adjustments?
Old Dec 9, 2007 | 10:37 PM
dcRay's Avatar
Default Re: valve adjustment on b18b (bara6075)
On a non-vtec no special tool is needed. Simply crack the 12mm nut loose with a rachet and then go from there.
Old Dec 9, 2007 | 10:42 PM
bara6075's Avatar
Default Re: valve adjustment on b18b (dcRay)
thanks man
10psiLsEf2
Apr 23, 2011 07:02 AM
saccord
May 5, 2006 08:14 AM
cstay
Aug 11, 2005 03:26 AM
Octoman
May 20, 2004 03:12 PM
daver
Oct 29, 2002 07:17 PM
