How hard is it to take out the dash
Old Dec 9, 2007 | 07:46 PM
onelugshortofpimpin's Avatar
Default How hard is it to take out the dash
Is there like a web sit wit some steps or somthing it looks like a pretty big job.
Old Dec 9, 2007 | 11:52 PM
BlueIntegraBoy's Avatar
Default Re: How hard is it to take out the dash (onelugshortofpimpin)
What year is your Civic? The 92-95 dashes are really easy to take it out.
Old Dec 10, 2007 | 03:31 AM
fusebox15's Avatar
i removed and installed the dash into my del sol 96' about 2 times by myself, its not as heavy as it looks, you can lift it with one hand, about 6 bolts altogether, just keep an eye on the wipers and headlight handles around steering wheel, you could be pressuring them to break if you're unaware, lower the steering position, remove a/c vents, remove the gauge cluster, remove the passanger box, unscrew gear *** and put gear into 4th and raise the mid console or remove it altogether for more space, and for even more convenience would be better to actually remove the steeringwheel, but you can still work around it.
Old Dec 10, 2007 | 04:11 AM
ej1-usdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onelugshortofpimpin &raquo;</TD></TR><TR><TD CLASS="quote">Is there like a web sit wit some steps or somthing it looks like a pretty big job. </TD></TR></TABLE>
pretty easy to do, but time comsuming
Old Dec 10, 2007 | 04:34 AM
blackeg's Avatar
Default Re: How hard is it to take out the dash (ej1-usdm)
the dash itself only weighs a few pounds. i think i have 4 bolts holding mine in, but maybe there are 6 altogether. be careful of the stalks around the steering column when u take it out, they are easy to break
Old Dec 10, 2007 | 05:51 AM
eknick021's Avatar
i've done it like 3 or 4 times already ... in different cars , is pretty easy just make sure you keep track where all the bolts and screws are located cuz i had like 10 screws left over everyhing else is pretty simple . go
Old Dec 10, 2007 | 09:57 AM
92yellowEG's Avatar
You also might think about getting a Haynes or Chilton shop manual, I have both and they have come in handy more than a few times!
Old Dec 10, 2007 | 10:27 AM
lowfast's Avatar
Little bit of time, and a little bit of patience, you'll get it.
89crxhf
12
Oct 7, 2012 09:18 PM
Skip01
Jul 16, 2009 04:16 PM
thatasiankidtony
Honda Civic (2006 - 2015)
Jun 14, 2007 12:43 PM
wannab20hatch
Mar 3, 2006 02:01 PM
projectcrx
Apr 26, 2002 04:25 AM
