which clutch & pp should i use
Which clutch would suite my application GSR engine ctr cams, y21 gear box exedy fly wheel, i have a exedy in there now and it;s dead, daily driver weekend racer...i dont want anything too tuff ie shaking out dash board
Exedy stage 1
Exedy stage 2
ACT Sport pp
ACT Heavy duty PP
With 6 pad sprung
Performance street disc
Exedy stage 1
Exedy stage 2
ACT Sport pp
ACT Heavy duty PP
With 6 pad sprung
Exedy stage 1 broke on me after 8 months. i couldnt get into gear and ended up limping the car back home on second gear when i miraculously got it in. towed the car to a shop to get it checked and replaced. they gave me back the clutch and a piece that holds the spring broke off, spring was in 2 pieces.
bought a OEM type r clutch ( same thing as non-integra i think) instead. they look more sturdy than the exedy, and hasn't caused a problem since. however, i kept my exedy PP in there because it was heavier duty than the stock one.
i pulled down my box today it is a exedy stage 1 in there, clutch springs broke out i bought the car with the clutch, i know it hasnt been in there car for more than 24 mths, pp still good but my mech recommended i change it, i think i going to go ACT street disc , HD pp any bad experienced with these ?
I'm running on an ACT HD PP with stock disc(because I had an extra laying around, otherwise would have went with ACT performance street disc) and 7.5lb Findanza and I love my set-up. PP really grabs when you need it too(enough that I got mount inserts cuz I was afraid for my mounts), normal driving though it feel just like stock pedal. My motor is almost like yours, GSR that I have 01 ITR cams waiting to go into it.
Cool Cool Island Breezes. BOY-EE
ACT= garbage. I've hated driving every ACT'd car i've ever driven.
Exedy stage 1 should work perfectly fine if your car's just on bolt ons. Smooth operation, and awesome grip and life. I've had this setup on a few cars. I have installed a new OEM exedy setup on my GSR a few months ago...and
Oh yea forgot, I had an OEM Exedy kit in my DA with the same Fidanza flywheel and everything was perfect also, but it doesn't grab like the ACT HD PP does.
the exedy i had in it took some getting use to i loved how it grabbed when race time but the pedal stiffness wasn't nice at all going act and see how it goes i will let u guys know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sihonda »</TD></TR><TR><TD CLASS="quote">i dont want anything too tuff ie shaking out dash board </TD></TR></TABLE>
It wont shake the dash unless you are a shitty driver.
Put OEM back in.....ricer
Since you're not going to make much more than stock power an OEM replacement clutch would be the best option. You could get something like the Exedy Stage 2 that i run, but its overkill for your setup. Stick with something inexpensive...stock replacement FTW
