will a 94/01 integra ls/rs/gs pulley kit fit a b20b engine?
Old Dec 9, 2007 | 06:19 PM
ek44's Avatar
Default will a 94/01 integra ls/rs/gs pulley kit fit a b20b engine?
looking at this kit Aem Tru Power Pulley Kit Part#:23-7008C for integra 94/01.
does any one know if the kit (pulley/belts) will fit and operate normal with a b20b engine?
will it be worth doing it?
thank you.
and how can i do a search on that on h-t?
Old Dec 10, 2007 | 07:37 PM
ek44's Avatar
Default Re: will a 94/01 integra ls/rs/gs pulley kit fit a b20b engine? (ek44)
anyone please....
Old Dec 10, 2007 | 11:36 PM
snm95ls's Avatar
Search is in the upper right hand portion of your screen.
Don't waste your money on janky *** pulleys.
Old Dec 11, 2007 | 07:18 AM
hondaboyB18C1's Avatar
Default Re: will a 94/01 integra ls/rs/gs pulley kit fit a b20b engine? (snm95ls)
yes as long as you have the belts to match the pulley's. The CRV pulley is larger diameter then the LS.
Old Dec 11, 2007 | 08:51 AM
boostedb20z's Avatar
^^^^^^^ and the timing marks are off too
Old Dec 11, 2007 | 12:55 PM
Default Re: (boostedb20z)
the B series all run 16 degrees + or - 2 degrees , the LS and B20 cranks are the same parts , the heads are the same the dizzy's are the same. i think you should compare the 2 pulleys side by side
Modified by hondaboyB18C1 at 11:19 PM 12/11/2007
Old Dec 11, 2007 | 01:49 PM
snm95ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20z &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^^^ and the timing marks are off too</TD></TR></TABLE>
Old Dec 11, 2007 | 08:29 PM
ek44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">yes as long as you have the belts to match the pulley's. The CRV pulley is larger diameter then the LS. </TD></TR></TABLE>
which crv pulley is larger then the LS pulley? the p/s or the alternator?
Old Dec 11, 2007 | 08:30 PM
ek44's Avatar
thanx and much appreciated to all that replied.
Old Dec 11, 2007 | 08:32 PM
ek44's Avatar
so... to answer my question with a direct and CONFIRMED answer:
will the LS pulley kit fit and operate normal (no problem at all / EXACTLY the same) with a crv engine is......: ????
yes or no???
Old Dec 12, 2007 | 02:56 AM
Default Re: (ek44)
the whole pulley is larger diameter all only the A/C belt will fit you just need to get the belt to match the pulley kit you have. I have a LS pulley on my B20vtec Civic and a LS pulley on my 1997 CRV B20B. just had to swap pwr.st & alt. belts
Old Dec 12, 2007 | 09:06 AM
andrew714's Avatar
Default Re: (hondaboyB18C1)
no it wont, i have both pulleys for sale, pm me if u need
Old Dec 14, 2007 | 05:13 PM
ek44's Avatar
thanx to all that replied.
now i understand.
much appreciated.
ank81006
Nov 13, 2008 08:16 AM
joshuakenglee
Feb 12, 2008 09:43 PM
