Hybrid Transmission. Will this combo work?
Old Dec 9, 2007 | 01:26 PM
USDM EG's Avatar
Default Hybrid Transmission. Will this combo work?
Im seriously thinking about hybriding my 1995 USDM GSR trans.
Im thinking of using:
JDM 4.785 Final Drive
OEM Honda TYPE-R LSD
LS 5th gear set
With that combo. It will make all my gears (minus 5th and 2nd [1.27MPH longer]) slighty shorter than USDM B16/USDM ITR Gear ratios, which is great because it will somewhat cover the weight disadvantage of my Integra.
Questions:
Would an LS 5th gear swap work with the GSR trans?
Old Dec 9, 2007 | 04:16 PM
Padawan's Avatar
Darth ModerVader
Default Re: Hybrid Transmission. Will this combo work? (USDM EG)
https://honda-tech.com/zerothread?id=2162252
Old Dec 9, 2007 | 04:49 PM
USDM EG's Avatar
Default Re: Hybrid Transmission. Will this combo work? (Padawan)
yeah i saw taht thread. However, i was wondering if its compatable with a GSR trans, not a B16.
Would I need to change both gears or only 1?
Old Dec 9, 2007 | 06:05 PM
IN VTEC's Avatar
You have to change the mainshaft and countershaft fifth gears. B-series hydro and cable parts are interchangeable if you use the right combination of parts.
Old Dec 10, 2007 | 05:12 AM
USDM EG's Avatar
Default Re: Hybrid Transmission. Will this combo work? (IN VTEC)
ok, so i have to get the mainshaft and transfer all my other gears and aprts over to taht one. (Im assuming the gear and shaft are all one piece then...?)
ill be sticking with hydro parts.
Old Dec 10, 2007 | 06:42 AM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">You have to change the mainshaft and countershaft fifth gears. B-series hydro and cable parts are interchangeable if you use the right combination of parts.</TD></TR></TABLE>
right combination usually doesn't include 90-91 cable transmission parts. 92-93 are the most hydro compatible
Old Dec 10, 2007 | 07:03 AM
USDM EG's Avatar
Default Re: Hybrid Transmission. Will this combo work? (IT GUY)
hmm.. well after pricing out a brand new LSD 4.85 and a slightly used LSD. Ive come to the conclusion that I would be better off buying an ITR trans.
Any idea on where people buy brand new ITR transmissions? Im looking to spend 1,000 dollars
tial-eg
May 15, 2006 06:41 PM
madhatter07
Sep 14, 2004 11:00 AM
4g4drb17
Jul 26, 2004 06:11 PM
andyboy
Jul 20, 2004 09:26 AM
Jdm91Teg
Sep 8, 2002 07:37 PM
