gsr or ls tranny?
Old Dec 9, 2007 | 10:46 AM
scspeed's Avatar
Default gsr or ls tranny?
I have a 94 acura integra with an ls nonvtec motor. its tubocharged and made 302 hp. Idk which one i should go with. I just resently blew my ls tranny and dont know if i should go with another or just get a gsr now. Im not realy worried about the gas milage, I just want somthing thats gunna be fast and reliable so i dont have to worry about it breaking again. lmk what you guys think..
Thx
Old Dec 9, 2007 | 10:50 AM
DC4 Dave's Avatar
The GSR transmission isn't necessarily stronger, it just has better gearing.
How did your LS trans break to begin with? Abuse will kill any transmission, but if yours simply wasn't maintained by the previous owner, I can see why it died.
It all depends on what you really want. If you liked the gearing in the LS transmission, then get another one. If you want closer/shorter gearing, go get a rebuild or fresh GSR trans. In either case, make sure there's NO GRINDS and it shifts smooth.
Old Dec 9, 2007 | 11:03 AM
tegG2's Avatar
Default Re: gsr or ls tranny? (scspeed)
The long third gear in the LS tranny if fun for turbos I think.
Old Dec 9, 2007 | 11:05 AM
igotvtec16's Avatar
gsr trans wit ls final
Old Dec 9, 2007 | 11:08 AM
scspeed's Avatar
Default Re: gsr or ls tranny? (tegG2)
The case had a crack in it and i ddint know, eventualy it ran dry with out knowing and blew it that way. Witch tranny do you think will be faster? or is it all on the way you look at it?
Old Dec 9, 2007 | 11:11 AM
DC4 Dave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scspeed &raquo;</TD></TR><TR><TD CLASS="quote">The case had a crack in it and i ddint know, eventualy it ran dry with out knowing and blew it that way. Witch tranny do you think will be faster? or is it all on the way you look at it?</TD></TR></TABLE>
Again, it depends on what you're doing with the car. The LS tranny is a monster on the top end, especially if you've got the power to pull your car to high speeds.
The GSR transmission is considered "faster" - the shorter gearing is going to get you up to speed quicker.
Many, many boosted cars run the GSR trans, and are competitive cars.
Old Dec 9, 2007 | 11:18 AM
scspeed's Avatar
Default Re: gsr or ls tranny? (DC4 Dave)
Ok thx alot man. Now what about the itr tranny. besides the lsd, how is that for gearing? is it in between both ls and gsr?
Old Dec 9, 2007 | 11:36 AM
igotvtec16's Avatar
someone correct me if im wrong but arent gears 1-3 on the gsr and itr the same,i thought i read that somewhere
Old Dec 9, 2007 | 12:19 PM
JDM_CRX_PLEASE's Avatar
LS tranny for boost
GSR/B16 tranny for N/A
for boost u want longer gears so u get the most out of ur boost
for N/A you want the GSR/b16 tranny because the gearing is shorter, ull get quicker acceleration and thats what u want from a all motor N/A.
Old Dec 9, 2007 | 12:31 PM
DAmnquickDA's Avatar
Default Re: (igotvtec16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotvtec16 &raquo;</TD></TR><TR><TD CLASS="quote">someone correct me if im wrong but arent gears 1-3 on the gsr and itr the same,i thought i read that somewhere</TD></TR></TABLE>
Wrong.
http://www.allmotorhonda.com/t...s.htm
B16 and GSR trannies arent for boost only. It really depends on tires/suspension setup IMO.
Shorter gearing equals faster acceleration. Period.
However, many people throw a B16 tranny on a boosted setup and spin thru 3rd or 4th gear and say its ****. They get an LS tranny and say its faster. Well no ****, now you have traction because youre accelerating SLOWER.
A friend of mine, and an HT member, has a 415 whp EG with an ITR tranny and a 4.9 final. He also has really good/sticky tires. He doesnt spin in 2nd or 3rd. He accelerates faster than a guy with an idenical setup with an LS tranny.
Get a good/short geared tranny (XSi with an LSD, GSR with an LSD etc) and dont cheap out on tires.
Old Dec 9, 2007 | 01:26 PM
integrag's Avatar
if your not going to go vtec turbo then stick with the ls tranny
Old Dec 9, 2007 | 01:31 PM
Mfoehrkolb's Avatar
gsr trans is a great tranny. if i had the time, i would put a ls 5ht in it thogh
Old Dec 9, 2007 | 06:08 PM
95teg_ls's Avatar
Default Re: (Mfoehrkolb)
look at how fast your turbo spools, i would stick with either a gsr or an ls tranny, i wouldnt go with a b16 or r
Old Dec 9, 2007 | 06:28 PM
scspeed's Avatar
Default Re: (95teg_ls)
Ok, well thx for all your help guys it helped me out alot. Now all i need to do is fine the tranny hah. So if anyones got one laying around give me a pm. thx
Old Dec 9, 2007 | 07:53 PM
turbociv910's Avatar
Default Re: (scspeed)
gsr tranny. best one for boost for the 1/4th
Old Dec 9, 2007 | 09:56 PM
LS tranny w/ LSD...
smash, have fun and not give a expletive
91EF919
Transmission & Drivetrain
May 18, 2009 06:51 PM
gsilnc
Apr 16, 2008 05:12 PM
BoOsTiN Dc2
Jun 9, 2005 02:35 PM
billyhoe
Oct 23, 2004 01:37 PM
94acurals
Aug 19, 2001 05:41 PM
